Datasheet LMH6714MA - National Semiconductor Даташит усилитель, VIDEO, 400 МГц, POWERWISE, SOIC8 — Даташит
Наименование модели: LMH6714MA
Купить LMH6714MA на РадиоЛоцман.Цены — от 48 до 370 ₽25 предложений от 22 поставщиков Интегральные микросхемы Линейные микросхемы - Усилители - Видеоусилители и Модули | |||
| LMH6714MA Texas Instruments | 48 ₽ | ||
| LMH6714MA/NOPB Texas Instruments | от 370 ₽ | ||
| LMH6714MA/NOPB Rochester Electronics | по запросу | ||
| LMH6714MA National Semiconductor | по запросу | ||
Описание: Усилитель, VIDEO, 400 МГц, POWERWISE, SOIC8
LMH6714/6720/6722 Wideband Video Op Amp; Single, Single with Shutdown and Quad
March 2003
General Description
The LMH6714/6720/6722 series combine National's VIP10TM high speed complementary bipolar process with National's current feedback topology to produce a very high speed op amp.
These amplifiers provide a 400MHz small signal bandwidth at a gain of +2V/V and a 1800V/µs slew rate while consuming only 5.6mA from ± 5V supplies. The LMH6714/6720/6722 series offer exceptional video performance with its 0.01% and 0.01° differential gain and phase errors for NTSC and PAL video signals while driving a back terminated 75 load. They also offer a flat gain response of 0.1dB to 120MHz. Additionally, they can deliver 70mA continuous output current. This level of performance makes them an ideal op amp for broadcast quality video systems. The LMH6714/6720/6722's small packages (SOIC & SOT23), low power requirement,
- Number of Amplifiers: 1
- Gain Bandwidth: 400 МГц
- Slew Rate: 1800 В/мкс
- Диапазон напряжения питания: ± 5 В ... ± 6 В
- Выходной ток: 70 мА
- Amplifier Output: Single Ended
- Amplifier Case Style: SOIC
- Количество выводов: 8
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: SOIC
- Amplifier Type: Video
- Полоса частот: 400 МГц
- Семейство: 6714
- IC Generic Number: 6714
- Input Offset Voltage Max: 5 мВ
- Рабочий диапазон температрур: -40°C ... +85°C
- Особенности ОУ: Single, Wideband Video Op Amp
- Output Current Max: 70 мА
- Output Type: Single Ended
- Ток потребления: 5.6 мА
- Напряжение питания номинальное: 6 В
- Способ монтажа: SMD
