Datasheet LMH6739MQ/NOPB - National Semiconductor Даташит ИС, VIDEO BUFFER TRPL PROG 16SSOP — Даташит
National Semiconductor LMH6739MQ/NOPB
Наименование модели: LMH6739MQ/NOPB
23 предложений от 17 поставщиков
Микросхема Видеоусилитель, TEXAS INSTRUMENTS LMH6739MQ/NOPB Buffer Amplifier, Triple Video, 3 Amplifiers, 750MHz, 3300V/µs, 8V to 12V, SSOP, 16Pins
LMH6739MQ/NOPB
190 ₽
LMH6739MQ/NOPB
260 ₽
LMH6739MQ/NOPB
590 ₽
LMH6739MQ/NOPB
Описание: ИС, VIDEO BUFFER TRPL PROG 16SSOP
data sheetСкачать Data Sheet
LMH6739 Very Wideband, Low Distortion Triple Video Buffer
December 10, 2007
General Description
The LMH6739 is a very wideband, DC coupled monolithic selectable gain buffer designed specifically for ultra high resolution video systems as well as wide dynamic range systems requiring exceptional signal fidelity.
Benefiting from National's current feedback architecture, the LMH6739 offers gains of -1, 1 and 2. At a gain of +2 the LMH6739 supports ultra high resolution video systems with a 400 MHz 2 VPP 3 dB Bandwidth. With 12-bit distortion level through 30 MHz (RL = 100), 2.3nV/Hz input referred noise, the LMH6739 is the ideal driver or buffer for high speed flash A/D and D/A converters. Wide dynamic range systems such as radar and communication receivers requiring a wideband amplifier offering exceptional signal purity will find the LMH6739's low input referred noise and low harmonic distortion make it an attractive solution. T
Данные для моделированияДанные для моделирования
  • Number of Amplifiers: 3
  • Gain Bandwidth: 750 МГц
  • Slew Rate: 3300 В/мкс
  • Диапазон напряжения питания: 8 В ... 12 В
  • Выходной ток: 90 мА
  • Amplifier Output: Single Ended
  • Amplifier Case Style: SSOP
  • Количество выводов: 16
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: SSOP
  • Amplifier Type: Buffer
  • Семейство: 6739
  • Рабочий диапазон температрур: -40°C ... +85°C
  • Output Current Max: 90 мА
  • Output Type: Current
  • Способ монтажа: SMD
На английском языке: Datasheet LMH6739MQ/NOPB - National Semiconductor IC, VIDEO BUFFER TRPL PROG 16SSOP
