Datasheet Linear Technology LT1010CN8#PBF — Даташит
СерияLT1010
МодельLT1010CN8#PBF
Быстрый буфер питания 150 мА
Datasheet LT1010
PDF, 704 Кб, Язык: анг., Файл закачен: 4 авг 2017, Страниц: 20
Fast ±150mA Power Buffer
44 предложений от 22 поставщиков
LT1010CN8
195 ₽
LT1010CN8
202 ₽
Рутоника
LT1010CN8#PBF
252 ₽
Microfind
LT1010CN8#PBF
818 ₽
КорпусN-8
Код корпусаN
Индекс корпуса05-08-1510 (N8)
Количество каналов1
Частота единичного усиления GBW30 МГц
Av Min Stable1 V/V
Avol60 дБ
Cload330000 пФ
Design ToolsLTspice Model
Enoise 1/f Corner80 Hz
Enoise Density20 нВ/rtГц
Экспортный контрольнет
Ibias75000 нА
Inoise 1/f Corner80 Hz
Iout375 мА
Isupply5 мА
Over-the-Topнет
Rail-to-Rail Inнет
Rail-to-Rail Outнет
SR200 В/мс
Shutdownнет
Single Supplyнет
ТипBUF
VinCM High (from V+)1 В
VinCM Low (from V-)1 В
Voh (from V+)1 В
Vol (from V-).2 В
Vos70 мВ
Vs макс.44 В
Vs мин.4.5 В
  • Designs for High Performance Voltage-to-Frequency Converters &mdash AN14
    PDF, 387 Кб, Файл опубликован: 1 мар 1986
    A variety of high performance V/F circuits is presented. Included are a 1Hz to 100MHz design, a quartz-stabilized type and a 0.0007% linear unit. Other circuits feature 1.5V operation, sine wave output an nonlinear transfer functions. A separate section examines the trade-offs and advantages of various approaches to V/F conversion.
  • Unique IC Buffer Enhances Op Amp Designs, Tames Fast Amplifiers &mdash AN16
    PDF, 421 Кб, Файл опубликован: 1 авг 1985
    This note describes some of the unique IC design techniques incorporated into a fast, monolithic power buffer, the LT1010. Also, some application ideas are described such as capacitive load driving, boosting fast op amp output current and power supply circuits.
  • Power Gain Stages for Monolithic Amplifiers &mdash AN18
    PDF, 2.5 Мб, Файл опубликован: 1 мар 1986
    This note presents output state circuits which provide power gain for monolithic amplifiers. The circuits feature voltage gain, current gain, or both. Eleven designs are shown, and performance is summarized. A generalized method for frequency compensation appears in a separate section.
  • Composite Amplifiers &mdash AN21
    PDF, 330 Кб, Файл опубликован: 1 июл 1986
    Applications often require an amplifier that has extremely high performance in several areas. For example, high speed and DC precision are often needed. If a single device cannot simultaneously achieve the desired characteristics, a composite amplifier made up of two (or more) devices can be configured to do the job. AN21 shows examples of composite approaches in designs combining speed, precision, low noise and high power.
  • Linear Circuits for Digital Systems &mdash AN31
    PDF, 1.5 Мб, Файл опубликован: 2 фев 1989
    Subtitled "Some Affable Analogs for Digital Devotees," discusses a number of analog circuits useful in predominantly digital systems. VPP generators for flash memories receive extensive treatment. Other examples include a current loop transmitter, dropout detectors, power management circuits, and clocks.
  • Applications for a New Power Buffer &mdash AN4
    PDF, 1.0 Мб, Файл опубликован: 23 сен 1984
    The LT1010 150mA power buffer is described in a number of useful applications such as boosted op amp, a feed-forward, wideband DC stabilized buffer, a video line driver amplifier, a fast sample-hold with hold step compensation, an overload protected motor speed controller, and a piezoelectric fan servo.
  • Bridge Circuits &mdash AN43
    PDF, 3.8 Мб, Файл опубликован: 1 июн 1990
    Subtitled "Marrying Gain and Balance," this note covers signal conditioning circuits for various types of bridges. Included are transducer bridges, AC bridges, Wien bridge oscillators, Schottky bridges, and others. Special attention is given to amplifier selection criteria. Appended sections cover strain gauge transducers, understanding distortion measurements, and historical perspectives on bridge readout mechanisms and Wein bridge oscillators.
  • Measurement and Control Circuit Collection &mdash AN45
    PDF, 1.2 Мб, Файл опубликован: 5 июн 1991
    A variety of measurement and control circuits are included in this application note. Eighteen circuits, including ultra low noise amplifiers, current sources, transducer signal conditioners, oscillators, data converters and power supplies are presented. The circuits emphasize precision specifications with relatively simple configurations.
  • High Speed Amplifier Techniques &mdash AN47
    PDF, 5.3 Мб, Файл опубликован: 1 авг 1991
    This application note, subtitled "A Designer's Companion for Wideband Circuitry," is intended as a reference source for designing with fast amplifiers. Approximately 150 pages and 300 figures cover frequently encountered problems and their possible causes. Circuits include a wide range of amplifiers, filters, oscillators, data converters and signal conditioners. Eleven appended sections discuss related topics including oscilloscopes, probe selection, measurement and equipment considerations, and breadboarding techniques.
  • A Seven-Nanosecond Comparator for Single Supply Operation &mdash AN72
    PDF, 882 Кб, Файл опубликован: 1 май 1998
    AN72 is an extensive discussion of the causes and cures of problems in very high speed comparator circuits. A separate applications section uses the 7ns LT1394 in V-to-F converters, crystal oscillators, clock skew generators, triggers, sampling configurations and a nanosecond pulse stretcher. Appendices cover related topics.
  • Understanding and Applying Voltage References &mdash AN82
    PDF, 172 Кб, Файл опубликован: 1 ноя 1999
    Just how do bandgaps and buried Zeners stack up against Weston cells? Did you know your circuit board may induce more drift in a reference than time and temperature? Learn the answers to these and other commonly asked reference questions ranging from burn-in recommendations to ΔVBE generation in this Application Note.
  • A Standards Lab Grade 20-Bit DAC with 0.1ppm/В° Drift: The Dedicated Art of Digitizing One Part Per Million &mdash AN86
    PDF, 540 Кб, Файл опубликован: 1 янв 2001
    This publication details a true 1ppm D-to-A converter. Total DC error of this processor corrected DAC remains within 1ppm from 18-32°C, including reference drift. DAC error exclusive of reference drift is substantially better. Construction details and performance verification techniques are included, along with a complete software listing.
  • Application Considerations and Circuits for a New Chopper-Stabilized Op Amp &mdash AN9
    PDF, 625 Кб, Файл опубликован: 5 авг 1986
    A discussion of circuit, layout and construction considerations for low level DC circuits includes error analysis of solder, wire and connector junctions. Applications include sub-microvolt instrumentation and isolation amplifiers, stabilized buffers and comparators and precision data converters.
Design Notes
  • A Precision Wideband Current Probe for LCD Backlight Measurement &mdash DN101
    PDF, 93 Кб, Файл опубликован: 1 апр 1995
  • Gain Trimming In Instrumentation Amplifier Based Systems &mdash DN51
    PDF, 78 Кб, Файл опубликован: 1 июн 1991
  • Signal Conditioning > Amplifiers > Operational Amplifiers (Op Amps) > High Voltage Amplifiers (>12V) | High Output Current Amplifiers (>100mA)
LT1010CN8PBF, LT1010CN8 PBF
На английском языке: Datasheet Linear Technology LT1010CN8#PBF
