Datasheet MAX4200ESA+ - Maxim Даташит BUFFER усилитель, SINGLE, L NOISE, 780 МГц — Даташит
Наименование модели: MAX4200ESA+
![]() 36 предложений от 19 поставщиков Интегральные микросхемы Аналоговая техника — усилители — инструменты, ОУ (операционные), буферные | |||
MAX4200ESA Maxim | 65 ₽ | ||
MAX4200ESA Maxim | 118 ₽ | ||
MAX4200ESA-T Maxim | по запросу | ||
MAX4200ESA+ Maxim | по запросу |
Производитель: Maxim
Описание: BUFFER усилитель, SINGLE, L NOISE, 780 МГц
19-1338; Rev 3; 3/07
Ultra-High-Speed, Low-Noise, Low-Power, SOT23 Open-Loop Buffers
________________General Description
The MAX4200MAX4205 are ultra-high-speed, openloop buffers featuring high slew rate, high output current, low noise, and excellent capacitive-load-driving capability.
The MAX4200/MAX4201/MAX4202 are single buffers, while the MAX4203/MAX4204/MAX4205 are dual buffers. The MAX4201/MAX4204 have integrated 50 termination resistors, making them ideal for driving 50 transmission lines. The MAX4202/MAX4205 include 75 back-termination resistors for driving 75 transmission lines. The MAX4200/MAX4203 have no internal termination resistors. The MAX4200MAX4205 use a proprietary architecture to achieve up to 780MHz -3dB bandwidth, 280MHz 0.1dB gain flatness, 4200V/µs slew rate, and ±90mA output current drive capability. They operate from ±5V supplies and draw only 2.2mA of quiescent current. These features, along with low-noise performance, make these buffers suitable for drivin
- Number of Amplifiers: 1
- Gain Bandwidth: 660 МГц
- Slew Rate: 4200 В/мкс
- Диапазон напряжения питания: ± 4 В ... ± 5.5 В
- Выходной ток: 90 мА
- Amplifier Output: Single Ended
- Amplifier Case Style: SOIC
- Количество выводов: 8
- SVHC: No SVHC (18-Jun-2010)
- Тип корпуса: SO
- Amplifier Type: Low Noise
- Полоса частот: 780 МГц
- Семейство: 4200
- Gain dB Max: 1 дБ
- Input Offset Voltage Max: 15 мВ
- Рабочий диапазон температрур: -40°C ... +85°C
- Output Current Max: 90 мА
- Settling Time: 12µs
- Ток потребления: 2.2 мА
- Напряжение питания номинальное: 12 В
- Способ монтажа: SMD
