Datasheet LMH6560MA - National Semiconductor Даташит BUFFER, QUAD 680 МГц CLOSED-LOOP, SMD — Даташит
Наименование модели: LMH6560MA
![]() 10 предложений от 9 поставщиков new in stock for immediate delivery | |||
LMH6560MA/NOPB Texas Instruments | от 56 ₽ | ||
LMH6560MA/NOPB Texas Instruments | 66 ₽ | ||
LMH6560MA National Semiconductor | по запросу | ||
LMH6560MA/NOPB Texas Instruments | по запросу |
Описание: BUFFER, QUAD 680 МГц CLOSED-LOOP, SMD
LMH6560 Quad, High-Speed, Closed-Loop Buffer
September 2004
General Description
The LMH6560 is a high speed, closed-loop buffer designed for applications requiring the processing of very high frequency signals.
While offering a small signal bandwidth of 680MHz, and a very high slew rate of 3100V/µs the LMH6560 consumes only 46mA of quiescent current for all four buffers. Total harmonic distortion into a load of 100 at 20MHz is -51dBc. The LMH6560 is configured internally for a loop gain of one. Input resistance is 100k and output resistance is but 1.5. Crosstalk between the buffers is only -55dB. These characteristics make the LMH6560 an ideal choice for the distribution of high frequency signals on printed circuit boards. Differential gain and phase specifications of 0.10% and 0.03° respectively at 3.58MHz make the LMH6560 well suited for the buffering of video signals. The device is fabricated on National's high speed VIP10 process using
- Number of Amplifiers: 4
- Gain Bandwidth: 680 МГц
- Количество выводов: 14
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: SOIC
- Amplifier Type: Buffer
- Полоса частот: 680 МГц
- Семейство: 6560
- IC Generic Number: 6560
- Input Offset Voltage Max: 20 мВ
- Количество логических функций: 6560
- Рабочий диапазон температрур: -40°C ... +85°C
- Output Current Max: 80 мА
- Output Type: Single Ended
- Slew Rate: 3100 В/мкс
- Напряжение питания номинальное: 10 В
- Способ монтажа: SMD
- Диапазон напряжения питания: 3 В ... 10 В
