Datasheet ADCMP606BKSZ-R2 - Analog Devices Даташит Компаратор, RAIL-RAIL, CML, SC70-6 — Даташит
Наименование модели: ADCMP606BKSZ-R2
Купить ADCMP606BKSZ-R2 на РадиоЛоцман.Цены — от 77 до 1 113 ₽14 предложений от 14 поставщиков Микросхема Компаратор, ANALOG DEVICES ADCMP606BKSZ-R2 Analog Comparator, Single, High Speed, 1, 1.25ns, 2.5V to 5.5V, SC-70, 6Pins | |||
| ADCMP606BKSZ-R2 Analog Devices | 77 ₽ | ||
| ADCMP606BKSZ-R2 Analog Devices | 295 ₽ | ||
| ADCMP606BKSZ-R2 Analog Devices | 299 ₽ | ||
| ADCMP606BKSZ-R2 Analog Devices | 654 ₽ | ||
Производитель: Analog Devices
Описание: Компаратор, RAIL-RAIL, CML, SC70-6
Rail-to-Rail, Very Fast, 2.5 V to 5.5 V, Single-Supply CML Comparators ADCMP606/ADCMP607
FEATURES
Fully specified rail to rail at VCCI = 2.5 V to 5.5 V Input common-mode voltage from -0.2 V to VCCI + 0.2 V CML-compatible output stage 1.25 ns propagation delay 50 mW @ 2.5 V power supply Shutdown pin Single-pin control for programmable hysteresis and latch (ADCMP607 only) Power supply rejection > 60 dB -40°C to +125°C operation
GENERAL DESCRIPTION
The ADCMP606 and ADCMP607 are very fast comparators fabricated on XFCB2, an Analog Devices, Inc., proprietary process.
These comparators are exceptionally versatile and easy to use. Features include an input range from VEE - 0.5 V to VCCI + 0.2 V, low noise, CML-compatible output drivers, and TTL-/CMOS-compatible latch inputs with adjustable hysteresis and/or shutdown inputs. The devices offer 1.25 ns propagation delay with 2.5 ps rms random jitter (RJ). Overdrive and slew rate dispersion are typically less than 50 ps. A flexible power supply
- Тип компаратора: High Speed
- Количество компараторов: 1
- Время отклика: 1 нс
- Тип выхода: CML
- Output Compatibility: CML
- Ток потребления: 20.5 мА
- Диапазон напряжения питания: 2.5 В ... 5.5 В
- Тип корпуса: SC-70
- Количество выводов: 6
- Рабочий диапазон температрур: -40°C ... +125°C
- Семейство: 606
- Способ монтажа: SMD
ADCMP606BKSZR2, ADCMP606BKSZ R2
