Datasheet LM2903M/NOPB - National Semiconductor Даташит Voltage компаратор ИС — Даташит
National Semiconductor LM2903M/NOPB
Наименование модели: LM2903M/NOPB
47 предложений от 21 поставщиков
Микросхема Компаратор, TEXAS INSTRUMENTS LM2903M/NOPB Analog Comparator, Dual, Precision, 2, 1.5µs, ± 1V to ± 18V, SOIC, 8Pins
LM2903M/NOPB
46 ₽
LM2903M/NOPB
82 ₽
Зенер
Россия и страны ТС
LM2903M/NOPB
от 84 ₽
Контест
LM2903M/NOPB
Описание: Voltage компаратор ИС
data sheetСкачать Data Sheet
LM193/LM293/LM393/LM2903 Low Power Low Offset Voltage Dual Comparators
August 2002
General Description
The LM193 series consists of two independent precision voltage comparators with an offset voltage specification as low as 2.0 mV max for two comparators which were designed specifically to operate from a single power supply over a wide range of voltages.
Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage. These comparators also have a unique characteristic in that the input common-mode voltage range includes ground, even though operated from a single power supply voltage. Application areas include limit comparators, simple analog to digital converters; pulse, squarewave and time delay generators; wide range VCO; MOS clock timers; multivibrators and high voltage digital logic gates. The LM193 series was designed to
На английском языке: Datasheet LM2903M/NOPB - National Semiconductor Voltage Comparator IC
