Datasheet LM2903N - National Semiconductor Даташит ИС, COMPARATOR DUAL, 2903, DIP8 — Даташит
Наименование модели: LM2903N
![]() 62 предложений от 31 поставщиков Интегральные микросхемы Линейные микросхемы - Компараторы | |||
LM2903N (LM2903P) | от 14 ₽ | ||
LM2903N ON Semiconductor | 19 ₽ | ||
LM2903N/NOPB Texas Instruments | от 112 ₽ | ||
LM2903N | 185 ₽ |
Описание: ИС, COMPARATOR DUAL, 2903, DIP8
LM193/LM293/LM393/LM2903 Low Power Low Offset Voltage Dual Comparators
August 2002
General Description
The LM193 series consists of two independent precision voltage comparators with an offset voltage specification as low as 2.0 mV max for two comparators which were designed specifically to operate from a single power supply over a wide range of voltages.
Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage. These comparators also have a unique characteristic in that the input common-mode voltage range includes ground, even though operated from a single power supply voltage. Application areas include limit comparators, simple analog to digital converters; pulse, squarewave and time delay generators; wide range VCO; MOS clock timers; multivibrators and high voltage digital logic gates. The LM193 series was designed to
- Comparator Type: Precision
- Number of Comparators: 2
- Response Time: 1.5µs
- IC Output Type: CMOS, MOS, TTL, DTL, ECL
- Ток потребления: 1 мА
- Диапазон напряжения питания: 2 В ... 36 В, ± 1 В ... ± 18 В
- Amplifier Case Style: DIP
- Количество выводов: 8
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: DIP
- Семейство: 2903
- Comparator Features: Dual Low Power
- IC Generic Number: 2903
- Количество логических функций: 2903
- Рабочий диапазон температрур: -40°C ... +85°C
- Output Type: TTL / DTL / ECL / MOS / CMOS Compatible
- Способ монтажа: Through Hole
