Datasheet LM293AN - STMicroelectronics Даташит ИС, COMPARATOR, DUAL, DIFF, 8-DIP — Даташит
STMicroelectronics LM293AN
Наименование модели: LM293AN
Микросхема Компаратор, STMICROELECTRONICS LM293AN Analogue Comparator, Low Power, 2, 1.3µs, ± 1V to ± 18V, DIP, 8Pins
LM293AN
Fairchild
11 ₽
LM293AN
97 ₽
LM293AN
LM293AN
Описание: ИС, COMPARATOR, DUAL, DIFF, 8-DIP
data sheetСкачать Data Sheet
LM193, LM293, LM393
Low power dual voltage comparators
Features
Wide single-supply voltage range or dual supplies: +2 V to +36 V or ±1 V to ±18 V Very low supply current (0.4 mA) independent of supply voltage (1 mW/comparator at +5 V) Low input bias current: 25 nA typ.
Low input offset current: ±5 nA typ. Low input offset voltage: ±1 mV typ. Input common-mode voltage range includes ground Low output saturation voltage: 250 mV typ. (Isink = 4 mA) Differential input voltage range equal to the supply voltage TTL, DTL, ECL, MOS, CMOS compatible outputs
DIP8 (Plastic package)
  • Comparator Type: Low Power
  • Number of Comparators: 2
  • Response Time: 1.3µs
  • Ток потребления: 1 мА
  • Диапазон напряжения питания: ± 1 В ... ± 18 В
  • Amplifier Case Style: DIP
  • Количество выводов: 8
  • Семейство: 293
  • Рабочий диапазон температрур: -40°C ... +105°C
  • Output Type: TTL / DTL / ECL / MOS / CMOS Compatible
На английском языке: Datasheet LM293AN - STMicroelectronics IC, COMPARATOR, DUAL, DIFF, 8-DIP
