Datasheet LM311NG - ON Semiconductor Даташит ИС, VOLT COMPARATOR, DIP8, 311 — Даташит
Наименование модели: LM311NG
![]() 11 предложений от 11 поставщиков Микросхема Компаратор, ON SEMICONDUCTOR LM311NG Analogue Comparator, General Purpose, 1, 200ns, 5V to 30V, DIP, 8Pins | |||
LM311NG ON Semiconductor | 25 ₽ | ||
LM311NG ON Semiconductor | по запросу | ||
Производитель: ON Semiconductor
Описание: ИС, VOLT COMPARATOR, DIP8, 311
Order this document by LM311/D
Highly Flexible Voltage Comparators
The ability to operate from a single power supply of 5.0 V to 30 V or ±15 V split supplies, as commonly used with operational amplifiers, makes the LM211/LM311 a truly versatile comparator.
Moreover, the inputs of the device can be isolated from system ground while the output can drive loads referenced either to ground, the VCC or the VEE supply. This flexibility makes it possible to drive DTL, RTL, TTL, or MOS logic. The output can also switch voltages to 50 V at currents to 50 mA. Thus the LM211/LM311 can be used to drive relays, lamps or solenoids.
LM311 LM211
HIGH PERFORMANCE VOLTAGE COMPARATORS
- Comparator Type: General Purpose
- Number of Comparators: 1
- Response Time: 200 нс
- IC Output Type: DTL, MOS, RTL, TTL
- Ток потребления: 2.4 мА
- Диапазон напряжения питания: 5 В ... 30 В
- Amplifier Case Style: DIP
- Количество выводов: 8
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: DIP
- Семейство: 311
- Comparator Features: Voltage компаратор
- IC Generic Number: 311
- Рабочий диапазон температрур: Commercial
- Количество логических функций: 311
- Output Type: RTL, DTL, TTL, MOS
- Способ монтажа: Through Hole
