Datasheet LM339AM - National Semiconductor Даташит COMPARATOR QUAD, SMD, SOIC14, 339 — Даташит
Наименование модели: LM339AM
Описание: COMPARATOR QUAD, SMD, SOIC14, 339
LP339 Ultra-Low Power Quad Comparator
August 2000
General Description
The LP339 consists of four independent voltage comparators designed specifically to operate from a single power supply and draw typically 60 µA of power supply drain current over a wide range of power supply voltages.
Operation from split supplies is also possible and the ultra-low power supply drain current is independent of the power supply voltage. These comparators also feature a common-mode range which includes ground, even when operated from a single supply. Applications include limit comparators, simple analog-to-digital converters, pulse, square and time delay generators; VCO's; multivibrators; high voltage logic gates. The LP339 was specifically designed to interface with the CMOS logic family. The ultra-low supply current makes the LP339 valuable in battery powered applications. n n n n Single supply operation Sensing at ground Compatible with CMOS logic family Pin-ou
- Comparator Type: Precision
- Number of Comparators: 4
- Response Time: 1.3µs
- IC Output Type: CMOS, MOS, TTL, DTL, ECL
- Ток потребления: 1 мА
- Диапазон напряжения питания: ± 1 В ... ± 18 В
- Amplifier Case Style: SOIC
- Количество выводов: 14
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: SOIC
- Семейство: 339
- Comparator Features: Low Power, Low Offset Voltage
- IC Generic Number: 339
- Рабочий диапазон температрур: Commercial
- Количество логических функций: 339
- Output Type: TTL / DTL / ECL / MOS / CMOS Compatible
- Способ монтажа: SMD
Дополнительные аксессуары:
- Electrolube - HTS35SL
