Datasheet LM339AM/NOPB - National Semiconductor Даташит ИС, COMPARATOR, QUAD, SMD — Даташит
National Semiconductor LM339AM/NOPB
Наименование модели: LM339AM/NOPB
47 предложений от 24 поставщиков
Микросхема Компаратор, TEXAS INSTRUMENTS LM339AM/NOPB Analog Comparator, Quad, Low Power, 4, 1.3µs, ± 1V to ± 18V, SOIC, 14Pins
LM339AM/NOPB
44 ₽
LM339AM/NOPB
63 ₽
LM339AM/NOPB
от 332 ₽
ТаймЧипс
LM339AMNOPB
Описание: ИС, COMPARATOR, QUAD, SMD
data sheetСкачать Data Sheet
LM139/LM239/LM339/LM2901/LM3302 Low Power Low Offset Voltage Quad Comparators
March 2004
General Description
The LM139 series consists of four independent precision voltage comparators with an offset voltage specification as low as 2 mV max for all four comparators.
These were designed specifically to operate from a single power supply over a wide range of voltages. Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage. These comparators also have a unique characteristic in that the input common-mode voltage range includes ground, even though operated from a single power supply voltage. Application areas include limit comparators, simple analog to digital converters; pulse, squarewave and time delay generators; wide range VCO; MOS clock timers; multivibrators and high voltage digital logic gates. The LM139 seri
  • Comparator Type: Precision
  • Number of Comparators: 4
  • Response Time: 1.3µs
  • IC Output Type: CMOS, MOS, TTL, DTL, ECL
  • Ток потребления: 1 мА
  • Диапазон напряжения питания: ± 1 В ... ± 18 В
  • Amplifier Case Style: SOIC
  • Количество выводов: 14
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: NSOIC
  • Рабочий диапазон температрур: 0°C ... +70°C
  • Output Type: TTL / DTL / ECL / MOS / CMOS Compatible
  • Способ монтажа: SMD
Дополнительные аксессуары:
  • Electrolube - SMA10SL
На английском языке: Datasheet LM339AM/NOPB - National Semiconductor IC, COMPARATOR, QUAD, SMD
