Datasheet LM339AN - National Semiconductor Даташит ИС, COMPARATOR QUAD, DIP14, 339 — Даташит
Наименование модели: LM339AN
Купить LM339AN на РадиоЛоцман.Цены — от 3.90 до 506 ₽64 предложений от 31 поставщиков Микросхема Компаратор, Comparator Quad ±18V/36V 14Pin PDIP Comparator Quad ±18V/36V 14Pin PDIP | |||
| LM339AN | 11 ₽ | ||
| LM339AN-SGS92 STMicroelectronics | по запросу | ||
| LM339ANS STMicroelectronics | по запросу | ||
| LM339AN/N STMicroelectronics | по запросу | ||
Описание: ИС, COMPARATOR QUAD, DIP14, 339
LM139/LM239/LM339/LM2901/LM3302 Low Power Low Offset Voltage Quad Comparators
March 2004
General Description
The LM139 series consists of four independent precision voltage comparators with an offset voltage specification as low as 2 mV max for all four comparators.
These were designed specifically to operate from a single power supply over a wide range of voltages. Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage. These comparators also have a unique characteristic in that the input common-mode voltage range includes ground, even though operated from a single power supply voltage. Application areas include limit comparators, simple analog to digital converters; pulse, squarewave and time delay generators; wide range VCO; MOS clock timers; multivibrators and high voltage digital logic gates. The LM139 seri
- Comparator Type: Precision
- Number of Comparators: 4
- Response Time: 1.3µs
- IC Output Type: CMOS, MOS, TTL, DTL, ECL
- Ток потребления: 1 мА
- Диапазон напряжения питания: 2 В ... 36 В, ± 1 В ... ± 18 В
- Amplifier Case Style: DIP
- Количество выводов: 14
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: DIP
- Семейство: 339
- Comparator Features: Quad High Performance
- IC Generic Number: 339
- Рабочий диапазон температрур: Commercial
- Количество логических функций: 339
- Output Type: TTL / DTL / ECL / MOS / CMOS Compatible
- Способ монтажа: Through Hole
