Datasheet LM339M - National Semiconductor Даташит COMPARATOR QUAD, SMD, SOIC14, 339 — Даташит
National Semiconductor LM339M
Наименование модели: LM339M
62 предложений от 29 поставщиков
Аналоговый компаратор, Точность, 4 Компаратора, 1.3 мкс, ± 1В до ± 18В, SOIC, 14 вывод(-ов)
Рутоника
LM339M
12 ₽
Элитан
LM339M
51 ₽
Зенер
Россия и страны ТС
LM339M/NOPB
от 107 ₽
Эиком
LM339M/NOPB
от 110 ₽
Описание: COMPARATOR QUAD, SMD, SOIC14, 339
data sheetСкачать Data Sheet
LM139/LM239/LM339/LM2901/LM3302 Low Power Low Offset Voltage Quad Comparators
March 2004
General Description
The LM139 series consists of four independent precision voltage comparators with an offset voltage specification as low as 2 mV max for all four comparators.
These were designed specifically to operate from a single power supply over a wide range of voltages. Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage. These comparators also have a unique characteristic in that the input common-mode voltage range includes ground, even though operated from a single power supply voltage. Application areas include limit comparators, simple analog to digital converters; pulse, squarewave and time delay generators; wide range VCO; MOS clock timers; multivibrators and high voltage digital logic gates. The LM139 seri
  • Comparator Type: Precision
  • Number of Comparators: 4
  • Response Time: 1.3µs
  • IC Output Type: CMOS, MOS, TTL, DTL, ECL
  • Ток потребления: 1 мА
  • Диапазон напряжения питания: 2 В ... 36 В, ± 1 В ... ± 18 В
  • Amplifier Case Style: SOIC
  • Количество выводов: 14
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: SOIC
  • Семейство: 339
  • Comparator Features: Quad Low Power
  • IC Generic Number: 339
  • Рабочий диапазон температрур: Commercial
  • Количество логических функций: 339
  • Output Type: TTL / DTL / ECL / MOS / CMOS Compatible
  • Способ монтажа: SMD
Дополнительные аксессуары:
  • Electrolube - HTS35SL
На английском языке: Datasheet LM339M - National Semiconductor COMPARATOR QUAD, SMD, SOIC14, 339
