Datasheet LM393DG - ON Semiconductor Даташит ИС, PRECISION COMP, DUAL, 1.3 мкс, SOIC-8 — Даташит
Наименование модели: LM393DG
34 предложений от 20 поставщиков ON SEMICONDUCTOR - LM393DG - Analog Comparator, Dual, Precision, 2 Comparators, 1.3 µs, ± 1V to ± 18V, SOIC, 8 Pins... | |||
| LM393DG ON Semiconductor | 8.10 ₽ | ||
| LM393DG4 Texas Instruments | 8.22 ₽ | ||
| LM393DG4 Texas Instruments | от 82 ₽ | ||
| LM393DG ON Semiconductor | по запросу | ||
Производитель: ON Semiconductor
Описание: ИС, PRECISION COMP, DUAL, 1.3 мкс, SOIC-8
LM393, LM293, LM2903, LM2903V, NCV2903 Low Offset Voltage Dual Comparators
The LM393 series are dual independent precision voltage comparators capable of single or split supply operation.
These devices are designed to permit a common mode range-to-ground level with single supply operation. Input offset voltage specifications as low as 2.0 mV make this device an excellent selection for many applications in consumer, automotive, and industrial electronics.
Features http://onsemi.com
8 1
- Тип компаратора: Precision
- Количество компараторов: 2
- Время отклика: 1.3 мкс
- Тип выхода: CMOS, MOS, Open-Collector / Drain, TTL
- Ток потребления: 400 мкА
- Диапазон напряжения питания: ± 1 В ... ± 18 В
