Datasheet LM393M/NOPB - National Semiconductor Даташит ИС, COMPARATOR, DUAL, SMD — Даташит
National Semiconductor LM393M/NOPB
Наименование модели: LM393M/NOPB
45 предложений от 22 поставщиков
Микросхема Компаратор, TEXAS INSTRUMENTS LM393M/NOPB Analog Comparator, Dual, Precision, 2, 1.3µs, ± 1V to ± 18V, SOIC, 8Pins
Рутоника
LM393M/NOPB
26 ₽
LM393M/NOPB
44 ₽
LM393M/NOPB
от 83 ₽
LM393M/NOPB
Описание: ИС, COMPARATOR, DUAL, SMD
data sheetСкачать Data Sheet
LM158/LM258/LM358/LM2904 Low Power Dual Operational Amplifiers
October 2005
General Description
The LM158 series consists of two independent, high gain, internally frequency compensated operational amplifiers which were designed specifically to operate from a single power supply over a wide range of voltages.
Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage. Application areas include transducer amplifiers, dc gain blocks and all the conventional op amp circuits which now can be more easily implemented in single power supply systems. For example, the LM158 series can be directly operated off of the standard +5V power supply voltage which is used in digital systems and will easily provide the required interface electronics without requiring the additional ± 15V power supplies. The LM358 and LM2904 are available in a chip s
  • Тип компаратора: Precision
  • Количество компараторов: 2
  • Время отклика: 1.3µs
  • Тип выхода: CMOS, MOS, TTL, DTL, ECL
  • Ток потребления: 1 мА
  • Диапазон напряжения питания: ± 1 В ... ± 18 В
  • Amplifier Case Style: SOIC
  • Количество выводов: 8
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: NSOIC
  • Рабочий диапазон температрур: 0°C ... +70°C
  • Способ монтажа: SMD
Дополнительные аксессуары:
  • Electrolube - SMA10SL
На английском языке: Datasheet LM393M/NOPB - National Semiconductor IC, COMPARATOR, DUAL, SMD
