Datasheet LM393N/NOPB - National Semiconductor Даташит ИС, COMPARATOR, DUAL — Даташит
National Semiconductor LM393N/NOPB
Наименование модели: LM393N/NOPB
47 предложений от 20 поставщиков
Микросхема Компаратор, TEXAS INSTRUMENTS LM393N/NOPB Analog Comparator, Dual, Precision, 2, 1.3µs, ± 1V to ± 18V, DIP, 8Pins
727GS
LM393N/NOPB
от 7.82 ₽
TradeElectronics
LM393N@NOPB
Hi-Tech Circuit Group
LM393N/NOPB
SUV System
LM393N/NOPB
Описание: ИС, COMPARATOR, DUAL
data sheetСкачать Data Sheet
LM193/LM293/LM393/LM2903 Low Power Low Offset Voltage Dual Comparators
August 2002
General Description
The LM193 series consists of two independent precision voltage comparators with an offset voltage specification as low as 2.0 mV max for two comparators which were designed specifically to operate from a single power supply over a wide range of voltages.
Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage. These comparators also have a unique characteristic in that the input common-mode voltage range includes ground, even though operated from a single power supply voltage. Application areas include limit comparators, simple analog to digital converters; pulse, squarewave and time delay generators; wide range VCO; MOS clock timers; multivibrators and high voltage digital logic gates. The LM193 series was designed to
  • Тип компаратора: Precision
  • Количество компараторов: 2
  • Время отклика: 1.3µs
  • Тип выхода: CMOS, MOS, TTL, DTL, ECL
  • Ток потребления: 1 мА
  • Диапазон напряжения питания: ± 1 В ... ± 18 В
  • Amplifier Case Style: DIP
  • Количество выводов: 8
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: DIP
  • Рабочий диапазон температрур: 0°C ... +70°C
На английском языке: Datasheet LM393N/NOPB - National Semiconductor IC, COMPARATOR, DUAL
