Datasheet LMC6772BIM/NOPB - National Semiconductor Даташит ИС, COMP DUAL MRPWR КМОП 8-SO — Даташит
Наименование модели: LMC6772BIM/NOPB
![]() 32 предложений от 17 поставщиков Микросхема Компаратор, TEXAS INSTRUMENTS LMC6772BIM/NOPB Analog Comparator, Dual, Micropower, 2, 4µs, 2.7V to 15V, SOIC, 8Pins | |||
LMC6772BIM/NOPB Texas Instruments | 77 ₽ | ||
LMC6772BIM/NOPB Texas Instruments | 230 ₽ | ||
LMC6772BIM/NOPB Texas Instruments | от 429 ₽ | ||
LMC6772BIM/NOPB Texas Instruments | от 432 ₽ |
Описание: ИС, COMP DUAL MRPWR КМОП 8-SO
LMC6772 Dual Micropower Rail-To-Rail Input CMOS Comparator with Open Drain Output
August 2000
General Description
The LMC6772 is an ultra low power dual comparator with a maximum 10 µA/comparator power supply current.
It is designed to operate over a wide range of supply voltages, with a minimum supply voltage of 2.7V. The common mode voltage range of the LMC6772 exceeds both the positive and negative supply rails, a significant advantage in single supply applications. The open drain output of the LMC6772 allows for wired-OR configurations. The open drain output also offers the advantage of allowing the output to be pulled to any voltage rail up to 15V, regardless of the supply voltage of the LMC6772. The LMC6772 is targeted for systems where low power consumption is the critical parameter. Guaranteed operation at supply voltages of 2.7V and rail-to-rail performance makes this comparator ideal for batte
- Тип компаратора: General Purpose
- Количество компараторов: 2
- Время отклика: 4µs
- Тип выхода: CMOS, MOS, Open-Collector / Drain, TTL
- Ток потребления: 12µ А
- Диапазон напряжения питания: 2.7 В ... 15 В
- Amplifier Case Style: SOIC
- Количество выводов: 8
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: SOIC
- Семейство: 6672
- Рабочий диапазон температрур: -40°C ... +85°C
- Способ монтажа: SMD
