Datasheet LMV761MA - National Semiconductor Даташит ИС, COMPARATOR, SMD, SOIC8, 761 — Даташит
Наименование модели: LMV761MA
![]() 40 предложений от 21 поставщиков LMV761/LMV762/LMV762Q Low Voltage, Precision Comparator with Push-Pull Output | IC COMP PREC PUSH-PULL OUT 8SOIC | |||
LMV761MA/NOPB Texas Instruments | от 25 ₽ | ||
LMV761MA/NOPB Texas Instruments | 106 ₽ | ||
LMV761MA Texas Instruments | по запросу | ||
Описание: ИС, COMPARATOR, SMD, SOIC8, 761
LMV761/LMV762 Low Voltage, Precision Comparator with Push-Pull Output
July 2002
General Description
The LMV761/762 are precision comparators intended for applications requiring low noise and low input offset voltage.
The LV761 single has a shutdown pin that can be used to disable the device and reduce the supply current. The LMV761 is available in a space saving SOT23-6 or SOIC-8 package. The LMV762 dual is available in SOIC-8 or MSOP-8 package. They feature a CMOS input and Push-Pull output stage. The Push-Pull output stage eliminates the need for an external pull-up resistor. The LMV761/762 are designed to meet the demands of small size, low power and high performance required by portable and battery operated electronics. The input offset voltage has a typical value of 200µV at room temp and a 1mV limit over temp.
- Тип компаратора: Precision
- Количество компараторов: 1
- Время отклика: 120 нс
- Тип выхода: Push Pull
- Ток потребления: 300µ А
- Диапазон напряжения питания: 2.7 В ... 5 В
- Amplifier Case Style: SOIC
- Количество выводов: 8
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: SOIC
- Семейство: 761
- IC Generic Number: 761
- Количество логических функций: 761
- Рабочий диапазон температрур: -40°C ... +125°C
- Способ монтажа: SMD
- Communication Function: SM COMPARATOR
