Datasheet LMV762MM - National Semiconductor Даташит Сдвоенный компаратор, SMD, MSOP8, 762 — Даташит
Наименование модели: LMV762MM
![]() 37 предложений от 21 поставщиков Микросхема Компаратор, TEXAS INSTRUMENTS LMV762MM Analogue Comparator, Dual, Precision, 2, 120ns, 2.7V to 5V, MSOP, 8Pins | |||
LMV762MM/NOPB Texas Instruments | от 41 ₽ | ||
LMV762MM/NOPB Texas Instruments | 220 ₽ | ||
LMV762MM/NOPB Texas Instruments | от 273 ₽ | ||
LMV762MM/NOPB Texas Instruments | по запросу |
Описание: Сдвоенный компаратор, SMD, MSOP8, 762
LMV761/LMV762 Low Voltage, Precision Comparator with Push-Pull Output
July 2002
General Description
The LMV761/762 are precision comparators intended for applications requiring low noise and low input offset voltage.
The LV761 single has a shutdown pin that can be used to disable the device and reduce the supply current. The LMV761 is available in a space saving SOT23-6 or SOIC-8 package. The LMV762 dual is available in SOIC-8 or MSOP-8 package. They feature a CMOS input and Push-Pull output stage. The Push-Pull output stage eliminates the need for an external pull-up resistor. The LMV761/762 are designed to meet the demands of small size, low power and high performance required by portable and battery operated electronics. The input offset voltage has a typical value of 200µV at room temp and a 1mV limit over temp.
- Тип компаратора: Precision
- Количество компараторов: 2
- Время отклика: 120 нс
- Тип выхода: Push Pull
- Ток потребления: 300 мкА
- Диапазон напряжения питания: 2.7 В ... 5 В
- Тип корпуса: MSOP
- Количество выводов: 8
- Рабочий диапазон температрур: -40°C ... +125°C
- SVHC: No SVHC (19-Dec-2011)
- Семейство: 762
- IC Generic Number: 762
- Количество логических функций: 762
- Communication Function: SM DUAL COMPARATOR
- Способ монтажа: SMD
