Datasheet LP339M - National Semiconductor Даташит COMPARATOR QUAD, SMD, SOIC14, 339 — Даташит
Наименование модели: LP339M
![]() 55 предложений от 27 поставщиков Аналоговый компаратор, 4 канала, Низкая Мощность, 4 Компаратора, 5 мкс, ± 1В до ± 18В, SOIC | |||
LP339M Texas Instruments | 76 ₽ | ||
LP339M National Semiconductor | 79 ₽ | ||
LP339M Texas Instruments | по запросу | ||
LP339M-NSC Texas Instruments | по запросу |
Описание: COMPARATOR QUAD, SMD, SOIC14, 339
LP339 Ultra-Low Power Quad Comparator
August 2000
General Description
The LP339 consists of four independent voltage comparators designed specifically to operate from a single power supply and draw typically 60 µA of power supply drain current over a wide range of power supply voltages.
Operation from split supplies is also possible and the ultra-low power supply drain current is independent of the power supply voltage. These comparators also feature a common-mode range which includes ground, even when operated from a single supply. Applications include limit comparators, simple analog-to-digital converters, pulse, square and time delay generators; VCO's; multivibrators; high voltage logic gates. The LP339 was specifically designed to interface with the CMOS logic family. The ultra-low supply current makes the LP339 valuable in battery powered applications. n n n n Single supply operation Sensing at ground Compatible with CMOS logic family Pin-ou
- Тип компаратора: Low Power
- Количество компараторов: 4
- Время отклика: 5µs
- Тип выхода: CMOS, MOS
- Ток потребления: 60µ А
- Диапазон напряжения питания: ± 1 В ... ± 18 В
- Amplifier Case Style: SOIC
- Количество выводов: 14
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: SOIC
- Семейство: 339
- Особенности компаратора: Quad Ultra Low Power
- IC Generic Number: 339
- Рабочий диапазон температрур: Commercial
- Количество логических функций: 339
- Способ монтажа: SMD
Дополнительные аксессуары:
- Electrolube - HTS35SL
