Datasheet LP339N - National Semiconductor Даташит ИС, COMPARATOR QUAD, DIP14, 339 — Даташит
Наименование модели: LP339N
![]() 58 предложений от 29 поставщиков Микросхема Компаратор, TEXAS INSTRUMENTS LP339N/NOPB Analog Comparator, Quad, General Purpose, 4, 8µs, 2V to 36V, DIP, 14Pins | |||
LP339N Texas Instruments | 29 ₽ | ||
LP339N-TIT-DN Texas Instruments | по запросу | ||
LP339N/PB Texas Instruments | по запросу | ||
Описание: ИС, COMPARATOR QUAD, DIP14, 339
LP339 Ultra-Low Power Quad Comparator
August 2000
General Description
The LP339 consists of four independent voltage comparators designed specifically to operate from a single power supply and draw typically 60 µA of power supply drain current over a wide range of power supply voltages.
Operation from split supplies is also possible and the ultra-low power supply drain current is independent of the power supply voltage. These comparators also feature a common-mode range which includes ground, even when operated from a single supply. Applications include limit comparators, simple analog-to-digital converters, pulse, square and time delay generators; VCO's; multivibrators; high voltage logic gates. The LP339 was specifically designed to interface with the CMOS logic family. The ultra-low supply current makes the LP339 valuable in battery powered applications. n n n n Single supply operation Sensing at ground Compatible with CMOS logic family Pin-ou
- Тип компаратора: Low Power
- Количество компараторов: 4
- Время отклика: 5µs
- Тип выхода: CMOS, MOS
- Ток потребления: 60µ А
- Диапазон напряжения питания: 2 В ... 30 В
- Amplifier Case Style: DIP
- Количество выводов: 14
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: DIP
- Семейство: 339
- Особенности компаратора: Quad Ultra Low Power
- IC Generic Number: 339
- Рабочий диапазон температрур: Commercial
- Количество логических функций: 339
- Способ монтажа: Through Hole
