Datasheet LPV7215MG - National Semiconductor Даташит ИС, компаратор, POWERWISE, SC-70-5 — Даташит
National Semiconductor LPV7215MG
Наименование модели: LPV7215MG
36 предложений от 19 поставщиков
Микросхема Компаратор, TEXAS INSTRUMENTS LPV7215MG/NOPB Analog Comparator, Single, General Purpose, 1, 4.5µs, 1.8V to 5.5V, SC-70, 5Pins
LPV7215MG/NOPB
от 29 ₽
LPV7215MG/NOPB
155 ₽
Контест
LPV7215MG
184 ₽
SUV System
LPV7215MG/NOPB
Описание: ИС, компаратор, POWERWISE, SC-70-5
data sheetСкачать Data Sheet
LPV7215 Micropower, CMOS Input, RRIO, 1.8V Push-Pull Output Comparator
December 13, 2007
LPV7215 Micropower, CMOS Input, RRIO, 1.8V, Push-Pull Output Comparator
General Description
The LPV7215 is an ultra low-power comparator with a typical power supply current of 580 nA.
It has the best-in-class power supply current versus propagation delay performance available among National's low-power comparators. The propagation delay is as low as 4.5 microseconds with 100 mV overdrive at 1.8V supply. Designed to operate over a wide range of supply voltages, from 1.8V to 5.5V, with guaranteed operation at 1.8V, 2.7V and 5.0V, the LPV7215 is ideal for use in a variety of batterypowered applications. With rail-to-rail common mode voltage range, the LPV7215 is well suited for single-supply operation. Featuring a push-pull output stage, the LPV7215 allows for operation with absolute minimum power consumption when driving any capacitive or resistive load. Available in a choice of space-saving packag
  • Тип компаратора: General Purpose
  • Количество компараторов: 1
  • Время отклика: 45 мкс
  • Тип выхода: Push Pull
  • Ток потребления: 790 нА
  • Диапазон напряжения питания: 1.8 В ... 5.5 В
  • Тип корпуса: SC-70
  • Количество выводов: 5
  • Рабочий диапазон температрур: -40°C ... +85°C
  • SVHC: No SVHC (19-Dec-2011)
  • Семейство: 7215
  • Способ монтажа: SMD
На английском языке: Datasheet LPV7215MG - National Semiconductor IC, COMPARATOR, POWERWISE, SC-70-5
