Datasheet Linear Technology LT1011CS8#PBF — Даташит
СерияLT1011
МодельLT1011CS8#PBF
Компаратор напряжения
Datasheet LT1011, LT1011A
PDF, 296 Кб, Язык: анг., Файл закачен: 7 авг 2017, Страниц: 20
Voltage Comparator
41 предложений от 23 поставщиков
Микросхема Компаратор, LINEAR TECHNOLOGY LT1011CS8#PBF Analog Comparator, Single, General Purpose, 1, 150ns, 3V to ± 18V, SOIC, 8Pins
LT1011CS8#PBF
от 81 ₽
LT1011CS8#PBF
109 ₽
LT1011CS8#TRPBF
от 168 ₽
МосЧип
LT1011CS8PBF
КорпусSO-8
Код корпусаS8
Индекс корпуса05-08-1610 (S8)
Количество каналов1
Design ToolsLTspice Model
Экспортный контрольнет
HysteresisNone
Isupply4 мА
Output Rise/Fall Time80, 10 нс
Prop Delay0.15 µs
Separate O/P SupplyNone
SubnameLT1011
Диапазон напряжения питания5V to В±15V
Vos0.6 мВ
Vs макс.36 В
Vs мин.3 В
LT1011A LT1011A
  • Circuit Techniques for Clock Sources &mdash AN12
    PDF, 150 Кб, Файл опубликован: 1 окт 1985
    Circuits for clock sources are presented. Special attention is given to crystal-based designs including TXCOs and VXCOs.
  • High Speed Comparator Techniques &mdash AN13
    PDF, 1.1 Мб, Файл опубликован: 1 апр 1985
    The AN13 is an extensive discussion of the causes and cures of problems in very high speed comparator circuits. A separate applications section presents circuits, including a 0.025% accurate 1Hz to 30MHz V/F converter, a 200ns 0.01% sample-hold and a 10MHz fiber-optic receiver. Five appendices covering related topics complete this note.
  • Designs for High Performance Voltage-to-Frequency Converters &mdash AN14
    PDF, 387 Кб, Файл опубликован: 1 мар 1986
    A variety of high performance V/F circuits is presented. Included are a 1Hz to 100MHz design, a quartz-stabilized type and a 0.0007% linear unit. Other circuits feature 1.5V operation, sine wave output an nonlinear transfer functions. A separate section examines the trade-offs and advantages of various approaches to V/F conversion.
  • Considerations for Successive Approximation A ->D Converters &mdash AN17
    PDF, 641 Кб, Файл опубликован: 1 дек 1985
    A tutorial on SAR type A/D converters, this note contains detailed information on several 12-bit circuits. Comparator, clocking, and preamplifier designs are discussed. A final circuit gives a 12-bit conversion in 1.8µs. Appended sections explain the basic SAR technique and explore D/A considerations.
  • Performance Enhancement Techniques for Three-Terminal Regulators &mdash AN2
    PDF, 975 Кб, Файл опубликован: 2 авг 1984
    This application note describes a number of enhancement circuit techniques used with existing 3-terminal regulators which extend current capability, limit power dissipation, provide high voltage output, operate from 110VAC or 220VAC without the need to switch transformer windings, and many other usefu application ideas.
  • Application Considerations for an Instrumentation Lowpass Filter &mdash AN20
    PDF, 2.8 Мб, Файл опубликован: 1 сен 1986
    Discusses the principles of operation of the LTC1062 and helpful hints for its application. Various application circuits are explained in detail with focus on how to cascade two LTC1062s and how to obtain notches. Noise and distortion performance are fully illustrated.
  • Some Thoughts on DC-DC Converters &mdash AN29
    PDF, 1.2 Мб, Файл опубликован: 1 окт 1988
    This note examines a wide range of DC/DC converter applications. Single inductor, transformer, and switched-capacitor converter designs are shown. Special topics like low noise, high efficiency, low quiescent current, high voltage, and wide-input voltage range converters are covered. Appended sections explain some fundamental properties of different types of converters.
  • Switching Regulator Circuit Collection &mdash AN30
    PDF, 606 Кб, Файл опубликован: 1 фев 1989
    Switching regulators are of universal interest. Linear Technology has made a major effort to address this topic. A catalog of circuits has been compiled so that a design engineer can swiftly determine which converter type is best. This catalog serves as a visual index to be browsed through for a specific or general interest.
  • Linear Technology Magazine Circuit Collection, Volume III &mdash AN67
    PDF, 1.2 Мб, Файл опубликован: 1 сен 1996
    Application Note 67 is a collection of circuits for data conversion, interface and signal processing from the first five years of Linear Technology. This application note includes circuits such as fast video multiplexers for high speed video, an ultraselective bandpass filter circuit with adjustable gain, and a fully differential, 8-channel, 12-bit A/D system. The categories included in this app note are data conversion, interface, filters, instrumentation, video/op amps and miscellaneous circuits.
  • Some Techniques for Direct Digitization of Transducer Outputs &mdash AN7
    PDF, 297 Кб, Файл опубликован: 1 фев 1985
    Analog-to-digital conversion circuits which directly digitize low level transducer outputs, without DC preamplification, are presented. Covered are circuits which operate with thermocouples, strain gauges, humidity sensors, level transducers and other sensors.
  • Power Conditioning Techniques for Batteries &mdash AN8
    PDF, 708 Кб, Файл опубликован: 1 май 1985
    A variety of approaches for power conditioning batteries is given. Switching and linear regulators and converters are shown, with attention to efficiency and low power operation. 14 circuits are presented with performance data.
  • Application Considerations and Circuits for a New Chopper-Stabilized Op Amp &mdash AN9
    PDF, 625 Кб, Файл опубликован: 5 авг 1986
    A discussion of circuit, layout and construction considerations for low level DC circuits includes error analysis of solder, wire and connector junctions. Applications include sub-microvolt instrumentation and isolation amplifiers, stabilized buffers and comparators and precision data converters.
Design Notes
  • LT1510 High Efficiency Lithium-Ion Battery Charger &mdash DN111
    PDF, 77 Кб, Файл опубликован: 1 сен 1995
  • Signal Conditioning > Comparators > High Speed Comparators
  • Space & Harsh Environment > Military Hermetic (M)
LT1011CS8PBF, LT1011CS8 PBF
На английском языке: Datasheet Linear Technology LT1011CS8#PBF
