Datasheet LTC6702HDC - Linear Technology Даташит ИС, компаратор, LV, UP, сдвоенный, 8DFN — Даташит
Наименование модели: LTC6702HDC
![]() 41 предложений от 20 поставщиков IC COMP LOW VOLT 8-DFN. Comparator General Purpose CMOS, Push-Pull, Rail-to-Rail, TTL 8-DFN (2x2). Linear - Comparators | |||
LTC6702HDC#TRPBF Analog Devices | 128 ₽ | ||
LTC6702HDC#TRMPBF Analog Devices | от 425 ₽ | ||
LTC6702HDC#TRPBF Analog Devices | по запросу | ||
LTC6702HDC-TRMPBF | по запросу |
Производитель: Linear Technology
Описание: ИС, компаратор, LV, UP, сдвоенный, 8DFN
LTC6702 Tiny Micropower, Low Voltage Dual Comparators FEATURES
n n n n n n n
DESCRIPTION
The LTC®6702 is an extremely small dual comparator designed to maximize battery life while providing both speed and low voltage operation in applications where board space is a premium.
These comparators operate on supplies between 1.7V and 5.5V, and have a maximum guaranteed propagation delay of 500ns while drawing only 30A maximum quiescent current. Internal hysteresis desensitizes the LTC6702 to input noise and makes it easy to use, even with slow moving signals. CMOS inputs allow the use of large source impedances. The LTC6702 is available in the 8-pin SOT-23 and the tiny 2mm Ч 2mm DFN package.
L, LT, LTC and LTM are registered trademarks of Linear Technology Corporation. All other trademarks are the property of their respective owners.
- Тип компаратора: High Speed
- Количество компараторов: 2
- Время отклика: 320 нс
- Тип выхода: CMOS, TTL
- Output Compatibility: CMOS, TTL
- Ток потребления: 30 мкА
- Диапазон напряжения питания: 1.7 В ... 5.5 В
- Тип корпуса: DFN
- Количество выводов: 8
- Рабочий диапазон температрур: -40°C ... +125°C
- SVHC: No SVHC (19-Dec-2011)
- Семейство: 6702
- Способ монтажа: SMD
