Datasheet MAX932CSA+ - Maxim Даташит COMPARATOR, DUAL, W/2%REF, 8SOIC — Даташит
Наименование модели: MAX932CSA+
Купить MAX932CSA+ на РадиоЛоцман.Цены — от 41 до 827 ₽25 предложений от 21 поставщиков IC COMPARATOR DUAL W/REF LP8SOIC. Comparator with Voltage Reference CMOS, TTL 8-SOIC. Linear - Comparators | |||
| MAX932CSA-TG069 Maxim | 47 ₽ | ||
| MAX932CSA-T Maxim | 584 ₽ | ||
| MAX932CSA-TG069 Analog Devices | по запросу | ||
| MAX932CSA+T Maxim | по запросу | ||
Производитель: Maxim
Описание: COMPARATOR, DUAL, W/2%REF, 8SOIC
19-0194; Rev 1; 2/97
Ultra Low-Power, Low-Cost Comparators with 2% Reference
_______________General Description
The MAX931-MAX934 single, dual, and quad micropower, low-voltage comparators plus an on-board 2% accurate reference feature the lowest power consumption available.
These comparators draw less than 4µA supply current over temperature (MAX931), and include an internal 1.182V ±2% voltage reference, programmable hysteresis, and TTL/CMOS outputs that sink and source current. Ideal for 3V or 5V single-supply applications, the MAX931-MAX934 operate from a single +2.5V to +11V supply (or a ±1.25V to ±5V dual supply), and each comparator's input voltage range extends from the negative supply rail to within 1.3V of the positive supply. The MAX931-MAX934's unique output stage continuously sources as much as 40mA. And by eliminating powersupply glitches that commonly occur when comparators change logic states, the MAX931-MAX934 minimize parasitic feedback, which makes them easier to use
- Тип компаратора: Low Power
- Количество компараторов: 2
- Время отклика: 12µs
- Тип выхода: CMOS, TTL
- Ток потребления: 3.1µ А
- Диапазон напряжения питания: 2.5 В ... 11 В
- Amplifier Case Style: SOIC
- Количество выводов: 8
- SVHC: No SVHC (18-Jun-2010)
- Тип корпуса: SOIC
- Семейство: 932
- Рабочий диапазон температрур: 0°C ... +70°C
- Способ монтажа: SMD
