Datasheet NCS2200AMUT1G - ON Semiconductor Даташит Компаратор, низкий VOLT, SMD, UDFN-6 — Даташит
Наименование модели: NCS2200AMUT1G
![]() 45 предложений от 18 поставщиков Микросхема Компаратор, ON SEMICONDUCTOR NCS2200AMUT1G Analogue Comparator, Rail to Rail, Low Voltage, 1, 1.1µs, 850mV to 6V, µDFN, 6Pins | |||
NCS2200AMUT1G ON Semiconductor | от 29 ₽ | ||
NCS2200AMUT1G ON Semiconductor | 63 ₽ | ||
NCS2200AMUT1G ON Semiconductor | от 94 ₽ | ||
NCS2200AMUT1G ON Semiconductor | по запросу |
Производитель: ON Semiconductor
Описание: Компаратор, низкий VOLT, SMD, UDFN-6
NCS2200 Series, NCS2200A Low Voltage Comparators
The NCS2200 Series is an industry first sub-one volt, low power comparator family.
These devices consume only 10 mA of supply current. They are guaranteed to operate at a low voltage of 0.85 V which allows them to be used in systems that require less than 1.0 V and are fully operational up to 6.0 V which makes them convenient for use in both 3.0 V and 5.0 V systems. Additional features include no output phase inversion with overdriven inputs, internal hysteresis, which allows for clean output switching, and rail-to-rail input and output performance. The NCS2200 Series is available in the tiny SOT-23-5 and SOT-23-6 package. There are eight options featuring two industry standard pinouts. Additionally, the NCS2200 and NCS2202 are available in the SC70-5 package. The NCS2200 is also available in the tiny DFN 2x2.2 package. The NCS2200A is available in UDFN 1.2x1.0 package. (Table 1) The NCS2201/3 Series in the SOT-23-6 package features an e
- Тип компаратора: Low Voltage
- Количество компараторов: 1
- Время отклика: 1.1 мкс
- Тип выхода: CMOS, MOS, Open-Collector / Drain, TTL
- Ток потребления: 10 мкА
- Диапазон напряжения питания: 850 мВ ... 6 В
- Тип корпуса: UDFN
- Количество выводов: 6
- Рабочий диапазон температрур: -40°C ... +105°C
- SVHC: No SVHC (19-Dec-2011)
- Семейство: 2200
- Особенности компаратора: Sub-one volt low power
- Количество каналов: 1
- Способ монтажа: SMD
