Datasheet LM2903MX/NOPB - National Semiconductor Даташит ИС, PRECISION COMP, DUAL, 1.5 мкс, SOIC-8 — Даташит
Наименование модели: LM2903MX/NOPB
![]() 38 предложений от 21 поставщиков Микросхема Компаратор, TEXAS INSTRUMENTS LM2903MX/NOPB Analogue Comparator, Dual, Low Power, 2, 1.5µs, 2V to 36V, ± 1V to ± 18V, SOIC,... | |||
LM2903MX/NOPB Texas Instruments | 18 ₽ | ||
LM2903MX/NOPB Texas Instruments | от 27 ₽ | ||
LM2903MX/NOPB | по запросу | ||
LM2903MX/NOPB Texas Instruments | по запросу |
Описание: ИС, PRECISION COMP, DUAL, 1.5 мкс, SOIC-8
LM193/LM293/LM393/LM2903 Low Power Low Offset Voltage Dual Comparators
August 2002
General Description
The LM193 series consists of two independent precision voltage comparators with an offset voltage specification as low as 2.0 mV max for two comparators which were designed specifically to operate from a single power supply over a wide range of voltages.
Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage. These comparators also have a unique characteristic in that the input common-mode voltage range includes ground, even though operated from a single power supply voltage. Application areas include limit comparators, simple analog to digital converters; pulse, squarewave and time delay generators; wide range VCO; MOS clock timers; multivibrators and high voltage digital logic gates. The LM193 series was designed to
- Тип компаратора: Precision
- Количество компараторов: 2
- Время отклика: 1.5 мкс
- Тип выхода: TTL/DTL/ECL/MOS/CMOS Compatible
- Ток потребления: 1 мА
- Диапазон напряжения питания: ± 1 В ... ± 18 В
