Datasheet LM361N/NOPB - National Semiconductor Даташит ИС, DIFFERENTIAL COMP, SINGLE 14 нс DIP14 — Даташит
National Semiconductor LM361N/NOPB
Наименование модели: LM361N/NOPB
37 предложений от 20 поставщиков
Микросхема Компаратор, TEXAS INSTRUMENTS LM361N/NOPB Analog Comparator, Single, Differential, 1, 14ns, 4.75V to 5.25V, 5V to 15V, -6V to -15V, DIP...
LM361N/NOPB
111 ₽
Зенер
Россия и страны ТС
LM361N/NOPB
от 141 ₽
LM361N/NOPB
727GS
LM361N/NOPB
Описание: ИС, DIFFERENTIAL COMP, SINGLE 14 нс DIP14
data sheetСкачать Data Sheet
LM161/LM361 High Speed Differential Comparators
August 2000
General Description
The LM161/LM361 is a very high speed differential input, complementary TTL output voltage comparator with improved characteristics over the SE529/NE529 for which it is a pin-for-pin replacement.
The device has been optimized for greater speed performance and lower input offset voltage. Typically delay varies only 3 ns for over-drive variations of 5 mV to 500 mV. It may be operated from op amp supplies ( ± 15V). Complementary outputs having maximum skew are provided. Applications involve high speed analog to digital converters and zero-crossing detectors in disk file systems.
  • Тип компаратора: Differential
  • Количество компараторов: 1
  • Время отклика: 14 нс
  • Тип выхода: TTL
  • Ток потребления: 20 мА
  • Диапазон напряжения питания: 4.75 В ... 5.25 В, 5 В ... 15 В, -6 В ... -15 В
На английском языке: Datasheet LM361N/NOPB - National Semiconductor IC, DIFFERENTIAL COMP, SINGLE 14 ns DIP14
