Datasheet LM393MX - National Semiconductor Даташит ИС, PRECISION COMP, DUAL, 1.3 мкс, SOIC-8 — Даташит
National Semiconductor LM393MX
Наименование модели: LM393MX
51 предложений от 28 поставщиков
Интегральные микросхемы Линейные микросхемы - Компараторы
LM393MX
4.77 ₽
LM393MX/NOPB
68 ₽
LM393MX/NOP
SUV System
LM393MX/NOPB
Описание: ИС, PRECISION COMP, DUAL, 1.3 мкс, SOIC-8
data sheetСкачать Data Sheet
LM193/LM293/LM393/LM2903 Low Power Low Offset Voltage Dual Comparators
August 2002
General Description
The LM193 series consists of two independent precision voltage comparators with an offset voltage specification as low as 2.0 mV max for two comparators which were designed specifically to operate from a single power supply over a wide range of voltages.
Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage. These comparators also have a unique characteristic in that the input common-mode voltage range includes ground, even though operated from a single power supply voltage. Application areas include limit comparators, simple analog to digital converters; pulse, squarewave and time delay generators; wide range VCO; MOS clock timers; multivibrators and high voltage digital logic gates. The LM193 series was designed to
  • Тип компаратора: Precision
  • Количество компараторов: 2
  • Время отклика: 1.3 мкс
  • Тип выхода: CMOS, MOS, TTL, DTL, ECL
  • Ток потребления: 1 мА
  • Диапазон напряжения питания: ± 1 В ... ± 18 В
На английском языке: Datasheet LM393MX - National Semiconductor IC, PRECISION COMP, DUAL, 1.3 µs, SOIC-8
