Datasheet LMV393MM/NOPB - National Semiconductor Даташит Компаратор, сдвоенный, 2.7-5.3 В, 8MSOP — Даташит
National Semiconductor LMV393MM/NOPB
Наименование модели: LMV393MM/NOPB
46 предложений от 18 поставщиков
Микросхема Компаратор, TEXAS INSTRUMENTS LMV393MM/NOPB Analog Comparator, Dual, General Purpose, 2, 200ns, 2.7V to 5V, MSOP, 8Pins
Эиком
LMV393MM/NOPB
от 128 ₽
LMV393MM/NOPB
от 129 ₽
LMV393MM/NOPB
от 135 ₽
LMV393MM/NOPB
Описание: Компаратор, сдвоенный, 2.7-5.3 В, 8MSOP
data sheetСкачать Data Sheet
LMV331 Single / LMV393 Dual / LMV339 Quad General Purpose, Low Voltage, Tiny Pack Comparators
May 2007
General Description
The LMV393 and LMV339 are low voltage (2.7-5V) versions of the dual and quad comparators, LM393/339, which are specified at 5-30V.
The LMV331 is the single version, which is available in space saving 5-pin SC70 and 5-pin SOT23 packages. The 5-pin SC70 is approximately half the size of the 5-pin SOT23. The LMV393 is available in 8-pin SOIC and MSOP. The LMV339 is available in 14-pin SOIC and TSSOP. The LMV331/393/339 is the most cost-effective solution where space, low voltage, low power and price are the primary specification in circuit design for portable consumer products. They offer specifications that meet or exceed the familiar LM393/339 at a fraction of the supply current. The chips are built with National's advanced Submicron Silicon-Gate BiCMOS process. The LMV33
  • Output Compatibility: CMOS, TTL
  • Время отклика: 200 нс
  • Диапазон напряжения питания: 2.7 В ... 5 В
  • Количество выводов: 8
  • Количество компараторов: 2
  • Рабочий диапазон температрур: -40°C ... +85°C
  • Тип выхода: CMOS, MOS, Open-Collector / Drain, TTL
  • Тип компаратора: General Purpose
  • Тип корпуса: MSOP
  • Ток потребления: 100 мкА
  • RoHS: да
  • SVHC: No SVHC (19-Dec-2011)
На английском языке: Datasheet LMV393MM/NOPB - National Semiconductor COMPARATOR, DUAL, 2.7-5.3 V, 8MSOP
