Заказные клавиатуры Accord по вашему ТЗ
Datasheet LMV7271MF/NOPB - National Semiconductor Даташит ИС, LOW POWER COMP, SINGLE 0.88 мкс SOT235 — Даташит
National Semiconductor LMV7271MF/NOPB
Наименование модели: LMV7271MF/NOPB
Описание: ИС, LOW POWER COMP, SINGLE 0.88 мкс SOT235
data sheetСкачать Data Sheet
LMV7271/LMV7275/LMV7272 Single & Dual, 1.8V Low Power Comparators with Rail-to-Rail Input
May 15, 2008
LMV7271/LMV7275/LMV7272 Single & Dual, 1.8V Low Power Comparators with Rail-toRail Input
General Description
The LMV727X are rail-to-rail input low power comparators, which are characterized at supply voltage 1.8V, 2.7V and 5.0V.
They consume only 9uA supply current per channel while achieving a 800ns propagation delay. The LMV7271/LMV7275 (single) are available in SC70 and SOT23 packages. The LMV7272 (dual) is available in micro SMD package. With these tiny packages, the PC board area can be significantly reduced. They are ideal for low voltage, low power and space critical designs. The LMV7271/LMV7272 both feature a push-pull output stage which allows operation with minimum power consumption when driving a load. The LMV7275 features an open drain output stage that allows for wired-OR configurations. The open drain output also offers the advantage of allowing the output to be pulle
  • Тип компаратора: General Purpose
  • Количество компараторов: 1
  • Время отклика: 880 нс
  • Ток потребления: 9 мкА
  • Диапазон напряжения питания: 1.8 В ... 5.5 В
  • Amplifier Case Style: SOT-23
  • Количество выводов: 5
На английском языке: Datasheet LMV7271MF/NOPB - National Semiconductor IC, LOW POWER COMP, SINGLE 0.88 µs SOT235
Политика конфиденциальности
