Datasheet LMV7291MG/NOPB - National Semiconductor Даташит ИС, LOW POWER COMP, SINGLE, 0.88 мкс SC705 — Даташит
National Semiconductor LMV7291MG/NOPB
Наименование модели: LMV7291MG/NOPB
51 предложений от 20 поставщиков
Аналоговый компаратор, Низкая Мощность, 1 Компаратор, 880 нс, 1.8В до 5В, SC-70, 5 вывод(-ов)
LMV7291MG/NOPB
от 25 ₽
LMV7291MG/NOPB
94 ₽
LMV7291MG/NOPB
119 ₽
Контест
LMV7291MG/NOPB
Описание: ИС, LOW POWER COMP, SINGLE, 0.88 мкс SC705
data sheetСкачать Data Sheet
LMV7291 Single 1.8V Low Power Comparator with Rail-to-Rail Input
March 2004
General Description
The LMV7291 is a rail-to-rail input low power comparator, characterized at supply voltage 1.8V, 2.7V and 5.0V.
It consumes only 9uA supply current per channel while achieving a 800ns propagation delay. The LMV7291 is available in SC70 package. With this tiny package, the PC board area can be significantly reduced. It is ideal for low voltage, low power and space critical designs. The LMV7291 features a push-pull output stage which allows operation with minimum power consumption when driving a load. The LMV7291 is built with National Semiconductor's advance submicron silicon-gate BiCMOS process. It has bipolar inputs for improved noise performance and CMOS outputs for rail-to-rail output swing.
  • Тип компаратора: General Purpose
  • Количество компараторов: 1
  • Время отклика: 880 нс
  • Тип выхода: Push Pull
  • Ток потребления: 14 мкА
  • Диапазон напряжения питания: 1.8 В ... 5 В
  • Amplifier Case Style: SC-70
На английском языке: Datasheet LMV7291MG/NOPB - National Semiconductor IC, LOW POWER COMP, SINGLE, 0.88 µs SC705
