Datasheet LMV761MA/NOPB - National Semiconductor Даташит ИС, PRECISION COMP, SINGLE, 0.12 мкс SOIC8 — Даташит
Наименование модели: LMV761MA/NOPB
Купить LMV761MA/NOPB на РадиоЛоцман.Цены — от 26 до 277 ₽38 предложений от 19 поставщиков Интегральные микросхемы Линейные микросхемы - Компараторы | |||
| LMV761MA/NOPB Texas Instruments | от 26 ₽ | ||
| LMV761MA/NOPB Texas Instruments | 107 ₽ | ||
| LMV761MA/NOPB Texas Instruments | от 277 ₽ | ||
| LMV761MA/NOPB Texas Instruments | по запросу | ||
Описание: ИС, PRECISION COMP, SINGLE, 0.12 мкс SOIC8
LMV761/LMV762/LMV762Q Low Voltage, Precision Comparator with Push-Pull Output
December 15, 2010
General Description
The LMV761/LMV762/LMV762Q are precision comparators intended for applications requiring low noise and low input offset voltage.
The LMV761 single has a shutdown pin that can be used to disable the device and reduce the supply current. The LMV761 is available in a space saving 6-Pin SOT-23 or 8-Pin SOIC package. The LMV762 dual is available in 8Pin SOIC or MSOP package and LMV762Q in MSOP package. They feature a CMOS input and Push-Pull output stage. The Push-Pull output stage eliminates the need for an external pull-up resistor. The LMV761/LMV762/LMV762Q are designed to meet the demands of small size, low power and high performance required by portable and battery operated electronics. The input offset voltage has a typical value of 200V at room temp and a 1mV limit over temp.
- Тип компаратора: Precision
- Количество компараторов: 1
- Время отклика: 120 нс
- Тип выхода: Push Pull
- Ток потребления: 2.75 мкА
- Диапазон напряжения питания: 2.7 В ... 5 В
- Amplifier Case Style: SOIC
