Datasheet LMV762MA/NOPB - National Semiconductor Даташит ИС, PRECISION COMP, DUAL, 0.12 мкс, SOIC-8 — Даташит
Наименование модели: LMV762MA/NOPB
![]() 44 предложений от 19 поставщиков Микросхема Компаратор, TEXAS INSTRUMENTS LMV762MA/NOPB Analog Comparator, Dual, Precision, 2, 120ns, 2.7V to 5V, SOIC, 8Pins | |||
LMV762MA/NOPB National Semiconductor | 110 ₽ | ||
LMV762MA/NOPB Texas Instruments | по запросу | ||
Описание: ИС, PRECISION COMP, DUAL, 0.12 мкс, SOIC-8
LMV761/LMV762/LMV762Q Low Voltage, Precision Comparator with Push-Pull Output
December 15, 2010
General Description
The LMV761/LMV762/LMV762Q are precision comparators intended for applications requiring low noise and low input offset voltage.
The LMV761 single has a shutdown pin that can be used to disable the device and reduce the supply current. The LMV761 is available in a space saving 6-Pin SOT-23 or 8-Pin SOIC package. The LMV762 dual is available in 8Pin SOIC or MSOP package and LMV762Q in MSOP package. They feature a CMOS input and Push-Pull output stage. The Push-Pull output stage eliminates the need for an external pull-up resistor. The LMV761/LMV762/LMV762Q are designed to meet the demands of small size, low power and high performance required by portable and battery operated electronics. The input offset voltage has a typical value of 200V at room temp and a 1mV limit over temp.
- Тип компаратора: Precision
- Количество компараторов: 2
- Время отклика: 120 нс
- Тип выхода: Push Pull
- Ток потребления: 2.75 мкА
- Диапазон напряжения питания: 2.7 В ... 5 В
- Amplifier Case Style: SOIC
