Datasheet LMV762MM/NOPB - National Semiconductor Даташит ИС, PRECISION COMP, DUAL, 0.12 мкс, MSOP-8 — Даташит
National Semiconductor LMV762MM/NOPB
Наименование модели: LMV762MM/NOPB
36 предложений от 19 поставщиков
Микросхема Компаратор, TEXAS INSTRUMENTS LMV762MM/NOPB Analog Comparator, Dual, Precision, 2, 120ns, 2.7V to 5V, MSOP, 8Pins
LMV762MM/NOPB
от 41 ₽
LMV762MM/NOPB
от 266 ₽
727GS
LMV762MM/NOPB
Hi-Tech Circuit Group
LMV762MM/NOPB
Описание: ИС, PRECISION COMP, DUAL, 0.12 мкс, MSOP-8
data sheetСкачать Data Sheet
LMV761/LMV762/LMV762Q Low Voltage, Precision Comparator with Push-Pull Output
December 15, 2010
General Description
The LMV761/LMV762/LMV762Q are precision comparators intended for applications requiring low noise and low input offset voltage.
The LMV761 single has a shutdown pin that can be used to disable the device and reduce the supply current. The LMV761 is available in a space saving 6-Pin SOT-23 or 8-Pin SOIC package. The LMV762 dual is available in 8Pin SOIC or MSOP package and LMV762Q in MSOP package. They feature a CMOS input and Push-Pull output stage. The Push-Pull output stage eliminates the need for an external pull-up resistor. The LMV761/LMV762/LMV762Q are designed to meet the demands of small size, low power and high performance required by portable and battery operated electronics. The input offset voltage has a typical value of 200V at room temp and a 1mV limit over temp.
  • Тип компаратора: Precision
  • Количество компараторов: 2
  • Время отклика: 120 нс
  • Тип выхода: Push Pull
  • Ток потребления: 2.75 мкА
  • Диапазон напряжения питания: 2.7 В ... 5 В
  • Amplifier Case Style: MSOP
На английском языке: Datasheet LMV762MM/NOPB - National Semiconductor IC, PRECISION COMP, DUAL, 0.12 µs, MSOP-8
