Datasheet LP339M/NOPB - National Semiconductor Даташит ИС, LOW POWER COMP, QUAD, 8 мкс, SOIC-14 — Даташит
National Semiconductor LP339M/NOPB
Наименование модели: LP339M/NOPB
34 предложений от 17 поставщиков
Микросхема Компаратор, TEXAS INSTRUMENTS LP339M/NOPB Analog Comparator, Quad, General Purpose, 4, 8µs, 2V to 36V, SOIC, 14Pins
LP339M/NOPB
105 ₽
LP339M/NOPB
110 ₽
727GS
LP339M/NOPB
LP339M/NOPB
Описание: ИС, LOW POWER COMP, QUAD, 8 мкс, SOIC-14
data sheetСкачать Data Sheet
LP339 Ultra-Low Power Quad Comparator
August 2000
General Description
The LP339 consists of four independent voltage comparators designed specifically to operate from a single power supply and draw typically 60 µA of power supply drain current over a wide range of power supply voltages.
Operation from split supplies is also possible and the ultra-low power supply drain current is independent of the power supply voltage. These comparators also feature a common-mode range which includes ground, even when operated from a single supply. Applications include limit comparators, simple analog-to-digital converters, pulse, square and time delay generators; VCO's; multivibrators; high voltage logic gates. The LP339 was specifically designed to interface with the CMOS logic family. The ultra-low supply current makes the LP339 valuable in battery powered applications. n n n n Single supply operation Sensing at ground Compatible with CMOS logic family Pin-ou
  • Тип компаратора: General Purpose
  • Количество компараторов: 4
  • Время отклика: 8 мкс
  • Тип выхода: CMOS Compatible
  • Ток потребления: 60 мкА
  • Диапазон напряжения питания: 2 В ... 36 В
  • Amplifier Case Style: SOIC
На английском языке: Datasheet LP339M/NOPB - National Semiconductor IC, LOW POWER COMP, QUAD, 8 µs, SOIC-14
