Datasheet LP339N/NOPB - National Semiconductor Даташит Voltage компаратор ИС — Даташит
Наименование модели: LP339N/NOPB
![]() 31 предложений от 15 поставщиков Микросхема Компаратор, TEXAS INSTRUMENTS LP339N/NOPB Analog Comparator, Quad, General Purpose, 4, 8µs, 2V to 36V, DIP, 14Pins | |||
LP339N/NOPB National Semiconductor | 41 ₽ | ||
LP339N/NOPB Texas Instruments | от 72 ₽ | ||
LP339N/NOPB Texas Instruments | от 107 ₽ | ||
LP339N/NOPB National Semiconductor | по запросу |
Описание: Voltage компаратор ИС
LP339 Ultra-Low Power Quad Comparator
August 2000
General Description
The LP339 consists of four independent voltage comparators designed specifically to operate from a single power supply and draw typically 60 µA of power supply drain current over a wide range of power supply voltages.
Operation from split supplies is also possible and the ultra-low power supply drain current is independent of the power supply voltage. These comparators also feature a common-mode range which includes ground, even when operated from a single supply. Applications include limit comparators, simple analog-to-digital converters, pulse, square and time delay generators; VCO's; multivibrators; high voltage logic gates. The LP339 was specifically designed to interface with the CMOS logic family. The ultra-low supply current makes the LP339 valuable in battery powered applications. n n n n Single supply operation Sensing at ground Compatible with CMOS logic family Pin-ou
