Datasheet LT1011ACN8 - Linear Technology Даташит Компаратор, DIFF, 30 В, 0.05 А, 8DIP — Даташит
Наименование модели: LT1011ACN8
![]() 40 предложений от 19 поставщиков IC: компаратор; универсальный; Cmp: 1; 250нс; THT; DIP8; туба | |||
LT1011ACN8 Linear Technology | 242 ₽ | ||
LT1011ACN8#PBF Analog Devices | от 351 ₽ | ||
LT1011ACN8LTC | по запросу | ||
LT1011ACN8PBF | по запросу |
Производитель: Linear Technology
Описание: Компаратор, DIFF, 30 В, 0.05 А, 8DIP
LT1011/LT1011A Voltage Comparator FEATURES
n n n n n n n n n n
DESCRIPTION
The LT®1011 is a general purpose comparator with significantly better input characteristics than the LM111.
Although pin compatible with the LM111, it offers four times lower bias current, six times lower offset voltage and five times higher voltage gain. Offset voltage drift, a previously unspecified parameter, is guaranteed at 15V/°C. Additionally, the supply current is lower by a factor of two with no loss in speed. The LT1011 is several times faster than the LM111 when subjected to large overdrive conditions. It is also fully specified for DC parameters and response time when operating on a single 5V supply. These parametric improvements allow the LT1011 to be used in high accuracy (12-bit) systems without trimming. In a 12-bit A/D application, for instance, using a 2mA DAC, the offset error introduced by the LT1011 is less than 0.5LSB. The LT1011 retains all the versatile features of the LM111, including s
- Output Compatibility: CMOS, TTL
- Влагостойкость: MSL 1 - Unlimited
- Время отклика: 150 нс
- Диапазон напряжения питания: 3 В ... ± 18 В
- Количество выводов: 8
- Количество компараторов: 1
- Рабочий диапазон температрур: 0°C ... +70°C
- Семейство: 1011
- Тип выхода: Open Collector
- Тип компаратора: General Purpose
- Тип корпуса: DIP
- Ток потребления: 3.2 мА
- RoHS: да
- SVHC: No SVHC (19-Dec-2011)
