Datasheet LT1017CN8 - Linear Technology Даташит Компаратор, сдвоенный, 1.1 TO 40 В, 8DIP — Даташит
Наименование модели: LT1017CN8
![]() 38 предложений от 20 поставщиков Микросхема Компаратор, Comparator Dual ±20V/40V 8Pin PDIP N | |||
LT1017CN8 Linear Technology | 168 ₽ | ||
LT1017CN8 Linear Technology | от 525 ₽ | ||
LT1017CN8 Analog Devices | 658 ₽ | ||
LT1017CN8 Linear Technology | по запросу |
Производитель: Linear Technology
Описание: Компаратор, сдвоенный, 1.1 TO 40 В, 8DIP
LT1017/LT1018 Micropower Dual Comparator FEATURES
n n n n n n n n
DESCRIPTION
The LT®1017/LT1018 are general purpose micropower comparators.
The LT1017 is optimized for lowest operating power while the LT1018 operates at higher power and higher speed. Both devices can operate from a single 1.1V cell up to 40V. The output stage includes a class "B" pullup current source, eliminating the need for an external resistive pull-up and saving power. The output stage is also designed to allow driving loads connected to a supply more positive than the device, as can comparators with open-collector output stages. Input specifications are also excellent. On-chip trimming minimizes offset voltage, while high gain and common mode rejection ratio keep other input referred errors low. Common mode voltage range includes ground. Special circuitry prevents false output states even if the input is overdriven. The LT1017/LT1018 are pin compatible with older dual comparators such as 393 type devices.
Maxi
- Диапазон напряжения питания: 1.1 В ... 40 В
- Количество выводов: 8
- Количество компараторов: 2
- Рабочий диапазон температрур: 0°C ... +70°C
- Тип выхода: Open Collector
- Тип компаратора: General Purpose
- Тип корпуса: DIP
- Ток потребления: 30 мкА
- RoHS: да
- SVHC: No SVHC (18-Jun-2012)
