Datasheet LT1394CS8 - Linear Technology Даташит High Speed компаратор ИС — Даташит
Наименование модели: LT1394CS8
Купить LT1394CS8 на РадиоЛоцман.Цены — от 88 до 1 210 ₽41 предложений от 22 поставщиков IC COMPARATOR LOW PWR 7NS 8-SOIC. Comparator with Latch CMOS, Complementary, TTL 8-SOIC. Linear - Comparators | |||
| LT1394CS8#PBF Analog Devices | 169 ₽ | ||
| LT1394CS8 Linear Technology | 213 ₽ | ||
| LT1394CS8 TRPBF Linear Technology | по запросу | ||
| LT1394CS8#TRPBF Analog Devices | по запросу | ||
Производитель: Linear Technology
Описание: High Speed компаратор ИС
FEATURES
s s s s s s s s s s s
LT1394 7ns, Low Power, Single Supply, Ground-Sensing Comparator DESCRIPTIO
The LT ®1394 is an UltraFast (7ns) comparator with complementary outputs and latch.
The input common mode range extends from 1.5V below the positive supply down to the negative supply rail. Like the LT1016, LT1116 and LT1671, this comparator has complementary outputs designed to interface directly to TTL or CMOS logic. The LT1394 may operate from either a single 5V supply or dual ±5V supplies. Low offset voltage specifications and high gain allow the LT1394 to be used in precision applications. The LT1394 is designed for improved speed and stability for a wide range of operating conditions. The output stage provides active drive in both directions for maximum speed into TTL, CMOS or passive loads with minimal cross-conduction current. Unlike other fast comparators, the LT1394 remains stable even for slow transitions through the active region, which eliminates the need to specify a
- Тип компаратора: High Speed
- Количество компараторов: 1
- Время отклика: 7 нс
- Тип выхода: TTL
- Ток потребления: 6 мА
- Amplifier Case Style: SOIC
- Количество выводов: 8
- Рабочий диапазон температрур: 0°C ... +70°C
