Datasheet MAX942EUA+ - Maxim Даташит компаратор SINGLE SUPPLY R/R, 942 — Даташит
Наименование модели: MAX942EUA+
Производитель: Maxim
Описание: Компаратор SINGLE SUPPLY R/R, 942
19-0229; Rev 7; 2/07
High-Speed, Low-Power, 3V/5V, Rail-to-Rail, Single-Supply Comparators
General Description
The MAX941/MAX942/MAX944 are single/dual/quad high-speed comparators optimized for systems powered from a 3V or 5V supply.
These devices combine high speed, low power, and rail-to-rail inputs. Propagation delay is 80ns, while supply current is only 350µA per comparator. The input common-mode range of the MAX941/ MAX942/MAX944 extends beyond both power-supply rails. The outputs pull to within 0.4V of either supply rail without external pullup circuitry, making these devices ideal for interface with both CMOS and TTL logic. All input and output pins can tolerate a continuous shortcircuit fault condition to either rail. Internal hysteresis ensures clean output switching, even with slow-moving input signals. The MAX941 features latch enable and device shutdown. The single MAX941 and dual MAX942 are offered in a tiny µMAX® package. Both the single and dual MAX942 are available in
- Тип компаратора: High Speed
- Количество компараторов: 2
- Время отклика: 80 нс
- Тип выхода: CMOS, TTL
- Ток потребления: 800 мА
- Диапазон напряжения питания: 2.7 В ... 5.5 В
- Amplifier Case Style: µMAX
- Количество выводов: 8
- SVHC: No SVHC (18-Jun-2010)
- Тип корпуса: µMAX
- Семейство: 942
- Количество логических функций: 942
- Рабочий диапазон температрур: -40°C ... +85°C
- Способ монтажа: SMD
