Datasheet NTE834 - MCM Даташит ИС, PRECISION COMP, QUAD, 1.3 мкс, DIP-14 — Даташит
MCM NTE834
Наименование модели: NTE834
29 предложений от 17 поставщиков
IC: компаратор; low-power; Cmp: 4; 1,3мкс; 2÷36В; SMT; SO14; 5нА
NTE834
от 34 ₽
NTE834SM
NTE Electronics
71 ₽
NTE834
NTE-834
Производитель: MCM
Описание: ИС, PRECISION COMP, QUAD, 1.3 мкс, DIP-14
data sheetСкачать Data Sheet
NTE834 & NTE834SM Integrated Circuit Low Power Low Offset Voltage Comparator
Description: The NTE834 and NTE834SM are precision voltage comparators designed to operate from a single power supply over a wide range of voltages.
Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage. These comparators also has a unique characteristic in that the input common-mode voltage range includes GND, even though operated from a single power supply voltage. Features: D Wide Single Supply Voltage Range: 2V to 36V D Very Low Supply Current Drain: 0.8mA Typ D Low Input Biasing Current: 25nA D Low Offset Voltage: ±3mV D Low Input Offset Current: ±5nA D Output Voltage Compatible with TTL, DTL, ECL, MOS, and CMOS Logic Systems D Available in Standard 14-Lead DIP (NTE834) and Surface Mount SOIC-14 (NTE834SM) Applications: D Limit Comparators D Simple Analog to Digital Converters D Pulse, Squarewave, and Time De
  • Тип компаратора: Precision
  • Количество компараторов: 4
  • Время отклика: 1.3 мкс
  • Тип выхода: TTL/DTL/ECL/MOS/CMOS Compatible
  • Ток потребления: 0.8 мА
  • Диапазон напряжения питания: 2 В ... 36 В
На английском языке: Datasheet NTE834 - MCM IC, PRECISION COMP, QUAD, 1.3 µs, DIP-14
