Datasheet NTE922 - NTE Electronics Даташит ИС, GEN PUR COMP, SINGLE 200 нс METAL CAN — Даташит
NTE Electronics NTE922
Наименование модели: NTE922
11 предложений от 10 поставщиков
Микросхема Компаратор, Comparator Single ±18V/36V 8Pin Metal Can
NTE922SM
NTE Electronics
от 495 ₽
Элитан
NTE922SM
NTE Electronics
2 533 ₽
NTE922M
NTE Electronics
NTE922
Производитель: NTE Electronics
Описание: ИС, GEN PUR COMP, SINGLE 200 нс METAL CAN
data sheetСкачать Data Sheet
NTE922, NTE922M, & NTE922SM Integrated Circuit Voltage Comparator
Description: The NTE922, NTE922M, and NTE922SM are voltage comparators that have input currents nearly a thousand times lower than devices like the NTE910 or NTE910D.
They are also designed to operate over a wider range of supply voltages: from standard ±15V op amp supplies down to the single 5V supply used for IC logic. Their output is compatible with RTL, DTL and TTL as well as MOS circuits. Further, they can drive lamps or relays, switching voltages up to 50V at currents as high as 50mA. Both the input and the output of these devices can be isolated from system ground, and the output can drive loads referred to ground, the positive supply or the negative supply. Offset balancing and strobe capability are provided and outputs can be wire OR'ed. Although slower than the NTE910 and NTE910D (200ns response time vs 40ns) the devices are also much less prone to spurious oscillations. Features: D Operates from single 5V supp
  • Тип компаратора: General Purpose
  • Количество компараторов: 1
  • Время отклика: 200 нс
  • Тип выхода: DTL, MOS, RTL, TTL
  • Ток потребления: 5.1 мА
  • Диапазон напряжения питания: 5 В ... ± 15 В
На английском языке: Datasheet NTE922 - NTE Electronics IC, GEN PUR COMP, SINGLE 200 ns METAL CAN
