Помощь в переводе проектов на ПЛИС азиатских брендов
Datasheet NTE943M - NTE Electronics Даташит ИС, PRECISION COMP, DUAL, 1.3 мкс, DIP-8 — Даташит
NTE Electronics NTE943M
Наименование модели: NTE943M
15 предложений от 10 поставщиков
Активная деталь, Comparator; Voltage Comparator; 36V or +/- 18V; 0.4mA (Typ.) @ +25C Supply
NTE943M
NTE Electronics
155 ₽
NTE943M
от 264 ₽
NTE943M
318 ₽
Hi-Tech Circuit Group
NTE943M
Производитель: NTE Electronics
Описание: ИС, PRECISION COMP, DUAL, 1.3 мкс, DIP-8
data sheetСкачать Data Sheet
NTE943, NTE943M, & NTE943SM Integrated Circuit Low Power, Low Offset, Dual Voltage Comparator
Description: The NTE943, NTE943M, and NTE943SM consist of two independent precision voltage comparators with an offset voltage speciication as low as 2.0mV max for two comparators which were designed specifically to operate from a single power supply over a wid range of voltages.
Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage. These comparators alos have a unique characteristic in that the input common­mode voltage range includesground, even though operated from a single powe supply voltage. Application areas include limit comparators, simple analog to digital converters; pulse, squarewave and time delay generators; wide range VCO; MOS clock timers; multivibrators and high voltage digital logic gates. These devices are designed to directly interface with TTL and CMOS. When operated from bot
  • Тип компаратора: Precision
  • Количество компараторов: 2
  • Время отклика: 1.3 мкс
  • Тип выхода: CMOS, MOS, TTL, DTL, ECL
  • Ток потребления: 1 мА
  • Диапазон напряжения питания: ± 1 В ... ± 18 В
  • Amplifier Case Style: DIP
На английском языке: Datasheet NTE943M - NTE Electronics IC, PRECISION COMP, DUAL, 1.3 µs, DIP-8
