Datasheet Texas Instruments LM2903QDRQ1 — Даташит
| Серия | LM2903-Q1 |
| Модель | LM2903QDRQ1 |
Автомобильный каталог Двойной дифференциальный компаратор 8-SOIC от -40 до 125
LM2903-Q1 Dual Differential Comparators datasheet
PDF, 1.2 Мб, Версия: E, Файл опубликован: 8 июл 2014
|  Купить LM2903QDRQ1 на РадиоЛоцман.Цены — от 6.05 до 145 ₽ 50 предложений от 21 поставщиков Микросхема Компаратор, TEXAS INSTRUMENTS LM2903QDRQ1 Analogue Comparator, Dual, Differential, 2, 1.3µs, 2V to 36V, ± 1V to ± 18V, SOIC, 8Pins... | |||
| LM2903QDRQ1 Texas Instruments | от 6.05 ₽ | ||
| LM2903QDRQ1 Texas Instruments | от 44 ₽ | ||
| LM2903QDRQ1 Texas Instruments | по запросу | ||
| Pin | 8 |
| Package Type | D |
| Industry STD Term | SOIC |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2500 |
| Carrier | LARGE T&R |
| Маркировка | 2903Q1 |
| Width (мм) | 3.91 |
| Length (мм) | 4.9 |
| Thickness (мм) | 1.58 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 1.75 |
| Mechanical Data | Скачать |
| Input Bias Current (+/-)(Max) | 50 нА |
| Iq per channel(Max) | 0.5 мА |
| Количество каналов | 2 |
| Тип выхода | Open Collector |
| Package Group | SOIC |
| Package Size: mm2:W x L | 8SOIC: 29 mm2: 6 x 4.9(SOIC) PKG |
| Propagation Delay Time | 1.3 uS |
| Rail-to-Rail | Out |
| Rating | Automotive |
| Special Features | N/A |
| VICR(Max) | 30.5 В |
| Vos (Offset Voltage @ 25C)(Max) | 7 мВ |
| Vs(Max) | 30 В |
| Vs(Min) | 2 В |
- Designing Overcurrent protection for TPL7407L Peripheral DriverPDF, 177 Кб, Файл опубликован: 5 ноя 2014
 Microcontroller units (MCUs) are generally limited with lower drive on the I/Os. Most of the applicationsrequiring MCU boards to drive high-current loads need discrete implementation and additional components which use a lot of board space. This board space is called a peripheral driver section. The TPL7407L device is an integrated peripheral driver with seven channel drivers inside. The TPL740
Серия: LM2903-Q1 (13)
- Semiconductors > Amplifiers > Comparators
