Datasheet LT6100CMS8 - Linear Technology Даташит ИС, SM, OP усилитель, CURRENT SENSE — Даташит
Наименование модели: LT6100CMS8
![]() 40 предложений от 21 поставщиков Микросхема Буферный усилитель, LINEAR TECHNOLOGY LT6100CMS8#PBF Current Sense Amplifier, Gain Selectable, 1 Amplifier, MSOP, 8Pins, -40℃, 85℃ | |||
LT6100CMS8#PBF Analog Devices | 93 ₽ | ||
LT6100CMS8#PBF Linear Technology | 134 ₽ | ||
LT6100CMS8#PBF Analog Devices | от 427 ₽ | ||
LT6100CMS8 | по запросу |
Производитель: Linear Technology
Описание: ИС, SM, OP усилитель, CURRENT SENSE
LT6100 Precision, Gain Selectable High Side Current Sense Amplifier DESCRIPTIO
The LT®6100 is a complete micropower, precision, high side current sense amplifier.
The LT6100 monitors unidirectional currents via the voltage across an external sense resistor. Fixed gains of 10, 12.5, 20, 25, 40, 50V/V are obtained by simply strapping or floating two gain select pins. Gain accuracy is better than 0.5% for all gains. The LT6100 sense inputs have a voltage range that extends from 4.1V to 48V, and can withstand a differential voltage of the full supply. This makes it possible to monitor the voltage across a MOSFET switch or a fuse. The part can also withstand a reverse battery condition on the inputs. Input offset is a low 300µV. CMRR and PSRR are in excess of 105dB, resulting in a wide dynamic range. A filter pin is provided to easily implement signal filtering with a single capacitor. The LT6100 has a separate supply input, which operates from 2.7V to 36V and draws only 60µA. When VCC is p
- Number of Amplifiers: 1
- Input Offset Voltage: 300 мкВ
- Gain dB Max: 50 дБ
- Полоса частот: 150 кГц
- CMRR: 120 дБ
- Slew Rate: 0.5 В/мкс
- Диапазон напряжения питания: 2.7 В ... 36 В
- Ток потребления: 60 мкА
- Amplifier Case Style: MSOP
- Количество выводов: 8
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: MSOP
- Тип усилителя: Current Sense
- Семейство: 6100
- Gain Bandwidth: 150 кГц
- Input Offset Voltage Max: 0.3 мВ
- Количество логических функций: 6100
- Рабочий диапазон температрур: -40°C ... +85°C
- Напряжение питания номинальное: 48 В
- Способ монтажа: SMD
Дополнительные аксессуары:
- Fischer Elektronik - ICK SMD A 10 SA
- Roth Elektronik - RE903
- STANNOL - 631954
