Datasheet LT6105CMS8 - Linear Technology Даташит ИС, CURRENT с усилитель, PRECI, 8MSOP — Даташит
Linear Technology LT6105CMS8
Наименование модели: LT6105CMS8
48 предложений от 21 поставщиков
LT6105CMS8#TRPBF
133 ₽
LT6105CMS8#TRPBF
222 ₽
LifeElectronics
LT6105CMS8-PBF
LT6105CMS8#TRPBF
Производитель: Linear Technology
Описание: ИС, CURRENT с усилитель, PRECI, 8MSOP
data sheetСкачать Data Sheet
LT6105 Precision, Extended Input Range Current Sense Amplifier FEATURES
n
DESCRIPTION
The LT®6105 is a micropower, precision current sense amplifier with a very wide input common mode range.
The LT6105 monitors unidirectional current via the voltage across an external sense resistor. The input common mode range extends from ­0.3V to 44V, with respect to the negative supply voltage (V ­). This allows the LT6105 to operate as a high side current sense monitor or a low side current sense monitor. It also allows the LT6105 to monitor current on a negative supply voltage, as well as continuously monitor a battery from full charge to depletion. The inputs of LT6105 can withstand differential voltages up to ±44V, which makes it ideal for monitoring a fuse or MOSFET switch. Gain is configured with external resistors from 1V/V to 100V/V. The input common mode rejection and power supply rejection are in excess of 100dB and the input offset voltage is less than 300V. A typical slew rate of 2V/s
  • Number of Amplifiers: 1
  • Output Current Per Channel: 1 мА
  • Input Offset Voltage: -100 мкВ
  • Gain dB Max: 100 дБ
  • Полоса частот: 100 кГц
  • CMRR: 120 дБ
  • Slew Rate: 2 В/мкс
  • Диапазон напряжения питания: 2.85 В ... 36 В
  • Ток потребления: 240 мкА
  • Amplifier Case Style: MSOP
  • Количество выводов: 8
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: MSOP
  • Семейство: 6105
  • Common Mode Voltage VCM: 44 В
  • Gain Bandwidth: 100 кГц
  • Рабочий диапазон температрур: 0°C ... +70°C
  • Способ монтажа: SMD
На английском языке: Datasheet LT6105CMS8 - Linear Technology IC, CURRENT s AMP, PRECI, 8MSOP
