Заказные клавиатуры Accord по вашему ТЗ
Datasheet MAX9929FAUA+ - Maxim Даташит CURRENT SENSE усилитель, 0.1~28 В, 8UMAX — Даташит
Maxim MAX9929FAUA+
Наименование модели: MAX9929FAUA+
Производитель: Maxim
Описание: CURRENT SENSE усилитель, 0.1~28 В, 8UMAX
data sheetСкачать Data Sheet
19-4251; Rev 0; 8/08
-0.1V to +28V Input Range, Micropower, Uni-/Bidirectional, Current-Sense Amplifiers
General Description
The MAX9928/MAX9929 low-cost, uni-/bidirectional, high-side, current-sense amplifiers are ideal for monitoring battery charge and discharge currents in notebooks, cell phones, and other portable equipment.
These devices feature a wide -0.1V to +28V input common-mode voltage range, low 20µA supply current with VOS less than 0.4mV, and a gain accuracy better than 1.0%. The input common-mode range is independent of the supply voltage, ensuring that the current-sense information remains accurate even when the measurement rail is shorted to ground. The MAX9928F/MAX9928T feature a current output with transconductance ratios of 5µA/mV and 2µA/mV, respectively. An external resistor converts the output current to a voltage, allowing adjustable gain so that the input sense voltage can be matched to the maximum ADC input swing. The MAX9929F/MAX9929T have a voltage output a
  • Number of Amplifiers: 1
  • Input Offset Voltage: 600 мкВ
  • Gain dB Max: 50 дБ
  • Полоса частот: 150 кГц
  • CMRR: 104 дБ
  • Диапазон напряжения питания: 2.5 В ... 5.5 В
  • Ток потребления: 115 мкА
  • Количество выводов: 8
  • SVHC: No SVHC (18-Jun-2010)
  • Тип корпуса: UMAX
  • Семейство: 9929
  • Bias Current: 1.6 мкА
  • Common Mode Voltage VCM: 28 В
  • Gain Bandwidth: 150 кГц
  • Рабочий диапазон температрур: -40°C ... +125°C
  • Способ монтажа: SMD
На английском языке: Datasheet MAX9929FAUA+ - Maxim CURRENT SENSE AMP, 0.1~28 V, 8UMAX
Политика конфиденциальности
