Datasheet HL2-HP-DC12V-F - Panasonic Даташит Мощное реле, 24 В постоянный ток, 10 А, DPDT, PCB — Даташит
Наименование модели: HL2-HP-DC12V-F
Реле Мощности, Power/Signal Relay, DPDT, Momentary, 0.075A (Coil), 12VDC (Coil), 900mW (Coil), DC Input, AC Output, Through Hole-Straight Mount, ROHS COMPLIANT...
HL2-HP-DC12V-F
Panasonic
1 050 ₽
HL2-HP-DC12V-F
Panasonic
HL2-HP-DC12V-F
Panasonic
727GS
HL2-HP-DC12V-F
Panasonic
АЦП азиатских производителей
Производитель: Panasonic
Описание: Мощное реле, 24 В постоянный ток, 10 А, DPDT, PCB
data sheetСкачать Data Sheet
HL
15A (1C), 10 A (2C) SPACE SAVING POWER RELAY
HL RELAYS
TYPICAL APPLICATIONS
Suitable for factory automation equipment and automotive devices 1.
Control panels, power supply equipment, molding equipment, machine tools, welding equipment, agricultural equipment, etc. 2. Office equipment, automatic vending machines, telecommunications equipment, disaster prevention equipment, copiers, measuring devices, medical equipment, amusement devices, etc. 3. All types of household appliance About Cd-free contacts We have introduced Cadmium free type products to reduce Environmental Hazardous Substances. (The suffix "F" should be added to the part number.) Please replace parts containing Cadmium with Cadmium-free products and evaluate them with your actual application before use because the life of a relay depends on the contact material and load.
  • Тип реле: Power
  • Coil Voltage VDC Nom: 24 В
  • Contact Current Max: 10 А
  • Contact Voltage AC Nom: 125 В
  • Contact Voltage DC Nom: 5 В
  • Coil Resistance: 160 Ом
  • Конфигурация контактов: DPDT
  • Coil Type: DC
HL2HPDC12VF, HL2 HP DC12V F
На английском языке: Datasheet HL2-HP-DC12V-F - Panasonic POWER RELAY, 24 V DC, 10 A, DPDT, PCB
